d16y8 head and d16y7 intake manifold
Old Jul 30, 2002 | 10:51 PM
98civicEX's Avatar
Default d16y8 head and d16y7 intake manifold
will the intake manifold fit the y8 head? thanks in advance guys...
Old Jul 30, 2002 | 11:36 PM
kinesistech's Avatar
Default Re: d16y8 head and d16y7 intake manifold (98civicEX)
Yes, the ports are equal length and have a less bias air flow design. However, the ports are smaller too, not that it matters since your booosted.
Just one more thing. Those manifolds use a 3 wire iacv. The only other civic engine I know of that uses the same sensor is the automatic ex. It will be a problem unlesss your's is auto.
Old Aug 14, 2002 | 06:05 PM
taikahn's Avatar
Default Re: d16y8 head and d16y7 intake manifold (kinesistech)
can you expand on that... ? So if I have a y7 and I add a y8 head w/ MT will I need a different manifold? can I keep the y7 manifold?
Old Aug 14, 2002 | 06:08 PM
raene's Avatar
Default Re: d16y8 head and d16y7 intake manifold (taikahn)
He's saying the IACVs are the different part, and are probably not interchangeable. There's two styles of IACV, rotary and... solenoid? Blehh, I forget. Anyway, I believe the rotary solenoid is the 3-wire one and the other type is a 2-wire. The connectors are a different shape and won't interchange.
Old Aug 14, 2002 | 06:25 PM
taikahn's Avatar
Default Re: d16y8 head and d16y7 intake manifold (raene)
So i CAN or I CANT use a y7 manifold on a y8 head (same year)?
Old Aug 15, 2002 | 02:53 AM
If you have a y7 you can use the y8 head but not intake manifold. Your stock manifold will work. The auto civic ex has the right manifold. It has bigger runners and a much bigger plenum. It also happens to use a TB with a 3 wire IAC just like yours. So you can use it if you can find one. I got mine.
Chavy340
Apr 29, 2012 12:03 PM
SpdFrk
Apr 23, 2006 07:47 PM
civic nation
Feb 28, 2006 05:54 PM
VTgringo
Aug 5, 2003 06:18 AM
CRXSleeper
Sep 18, 2002 05:19 PM
