top pipe rubbing tranny mount on DRAG 3 piping?
i have the DRAG 3 piping on my turbo setup, the top pipe touches the tranny mount,is there anything i can do? this is on a hybrid btw, 93 civic w/ GSR swap.
im just worried w/ the engine rocking the piping will get damaged over time, cant bend the pipe so the only thing ive thought of is maybe putting a piece of rubber underneath it? any tips>?
It's kinda stupid and obvious but losen the clamps and make sure the piping is all the way butted against the throttlebody and pipe that comes from the intercooler. You can cheat the piping quite a bit to make it work. If worse comes to worse put something between the mount and the pipe becuase it will eventually wear a hole.
oh i forgot, you might have to cut the end of the i/c piping that goes to the throttle body, this makes it a little shorter and makes it fit better, i had to do this on my h23a. just use a hacksaw on it, but make sure if you cut it to sand off the edges of the pipes so no metal goes into the motor.
thanks guys, i'll try those tips out.
now my freaking tial bumps the hood!
looks like i have to buy the elbow, suks major goose nuts, but i love every minute of it
actually its the entire tial hitting the hood, i have to buy the elbow that connects to the manifold,i have the maxrev mani sooooo,i guess it dont fit quite as well when u have a gsr powered civic
oh great, i'll get the elbow see if that helps. trim the sheetmetal seems pretty tough to do though...
NapTownSi
Feb 27, 2004 04:05 AM
