need paint tips
Old Nov 11, 2008 | 01:32 PM
backfromthedead's Avatar
Default need paint tips
well i have a small project lol well really big for some one who have never painted a car before so i have some Q? for the gurus i see lots of nice work here so i think i will get lots of info
1-i want to take the doors fenders bumper and everything i can take of the frame of the car is this good idea
the reason why i want this is because the car was painted before and have lots of different colors in different area
2- i have a paint gun already but is not gravity fed what is the difference and whats best o and how many do i have
3-what is the difference in the tips of the guns
4-how much paint will i need to paint the inside and out of the car
i will add more Q? later as we go thanks for the info in advance
Old Nov 11, 2008 | 05:21 PM
syzurs's Avatar
Default Re: need paint tips (backfromthedead)
you can take everything off the car and paint it if you want to paint the jams. I would tape everything up and paint the jams first (once everything is preped). then tape the rest and paint the outside.
gun prefrences are up to to the painter. you do waste a little more product if you use a siphon feed vs a gravity. the real question is if you have a conventional gun or a hvlp gun.
different tips are for shooting different things. heavy primer is used with a bigger tip. paint and clear should be shot with a smaller tip.
depending on the car and color i would say about a gallon for a whole car and jams. maybe a little more if you want to spray the inside. a lot of guys will shoot the inside with single stage so they don't have to clear.
Old Nov 11, 2008 | 05:52 PM
Default Re: need paint tips (syzurs)
thanks for you reply
i like to paint the hall car in and out so everything will be one colors the car i want to paint is and integra gsr the original color was green now is white but when you take the panels o some parts are green i want to paint the engine bay black and then the cab white
so if i take all the doors and bumpers is a good idea i can paint everything sepr and should i do all this the same day or i can do one at the time
one more Q? how i have to handle the paint in the gun how long can it stay in it between different coats
thanks
Old Nov 12, 2008 | 04:37 PM
well today o order this guns from ebay Devilbiss HVLP Auto Paint & Touch-Up Spray Gun i think they are good just don't know much about the brand
are they any good o is just a normal spray gun
Old Nov 12, 2008 | 05:00 PM
WeirdBeard's Avatar
Default Re: (backfromthedead)
devilbiss is an ok brand. Do you have any experience with auto body? Prepping and painting a car is a tricky task. By tricky I mean, there are allot of tricks that make a prep/paint job look good. I don't intend to imply you won't do a good job, or learn a thing or two from any mistakes, a "full dip" is allot of work. I'm new to hondaTech but auto body isn't something I think you can learn in forums.
Anyway, fer what ur up to.... I think a partial disassemble will save you a ton of hurt.
Open the doors.
loosen the bumper cover.
pop the hatch and hood.
Tape off really good.
you could get a cheap paint job at macco for the price of a really good paint gun.
Macco isn't the best, but you get your moneys worth.
Old Nov 12, 2008 | 05:44 PM
Default Re: (WeirdBeard)
thanks for the info but i really have a big problem i love to DIY and this car is a big project i know but in a second hand i am really handy and learn really fast
lol i am just trying to be proud of to say i did it lol i hope you understand me
Old Nov 14, 2008 | 06:33 AM
dSol-93's Avatar
1. good idea to take doors/fenders off the car=easy access to problem areas but can become a MAJOR problem if you cannot put them back on correctly because they need to be shimmed to properly fit the body lines again.
2. Go with gravity feed. Nuff said.
3. there are many varieties of tips for the guns but syzurs is correct about the tips
4. your probably going to need a gallon of paint too.
most importly the secret behind a good paint job is good body work. if the bodywork on your car is shabby before a paintjob down the road in a few years you will be kicking your self in the ***!
hope i could help!
Old Nov 15, 2008 | 05:22 PM
syzurs's Avatar
Devilbiss hvlp are good guns. they make an entery level gun called finishline, it think. is it a dual stage? most hvlp guns require 13-15 cfm of air at 40 psi. most compressors can't handle that unless they are a dual stage motor.
you can take all the parts you want off but it will only cause more work for you. if you have the time, then go for it.
how long you can leave paint in a gun? it depends on the product. ask the person you are buying paint from to see what the "pot life" is and they will tell you.
Macco isn't to bad. they just don't prep the car that well or at all. it's not that hard to spray a car, but it's hard to prep it correctly.
dSol-93 is right, your if your body work sucks, your paint job will suck.
Old Nov 15, 2008 | 08:11 PM
Default Re: (syzurs)
thanks guys for the replys i i do have time there is no rush on this project but i want it to come out all one color here are some pictures so you can see why i want to take everything off
Old Nov 15, 2008 | 08:12 PM
Old Nov 16, 2008 | 11:19 AM
WeirdBeard's Avatar
Now I SEE. OK! How bout some pics. of the pillar between the door and fender? You want to paint the engine bay and Interior too, right? That car is already striped, you have like 30 bolts to take out and your done. Tip: use zip lock bags or cups and boxes to store and label your hardware. Don't be shy with the labeling, the more specific you are the better. Red scotch-brite and some ting, or detro-clean, or Ajax, will be your best buddy. I'm interested again now that you posted some pics.
Old Nov 16, 2008 | 02:32 PM
hey thanks for your help i will get you the pictures tomorow i really will apreciated the help this is a project i will like to do my self
here are some new pictures for todays work
some more work on the bay
dash is out
Old Nov 18, 2008 | 04:14 PM
well here is some updates on this restoration lol i just got this in the mail now we can get ready for more fun working on the car
now i have to get me a sander i need to disede on the air 6" o the electric 6" for the prep
Old Nov 25, 2008 | 05:41 AM
JDMCRX's Avatar
Bump i love DIY
Old Nov 25, 2008 | 05:38 PM
i will be updating more this weeck end i will try to sand and prime the car is a long weeck end for me i will try to make much
BTW LOL
what grade sand paper is best to use lol
Old Nov 25, 2008 | 06:06 PM
SuperTuner12010's Avatar
Im really into this, im going to be doing the exact same thing soon. I have a red eh2 hatch with a primer body
Only problem I have, is I dont have a garge to paint in, im thinking of building a small building to paint it though...Hopefully...
Sand Paper depends on what stage your at, and how nice you want it to be...The more sanding the better it will be. Also the type of paint you use will make a difference.
Im doing the Rustoleum paint job withc consists of using rustoleum paint. You can get it at most home improvement stores. Its cheap, and there is no need to primer or even clear with this paint.
For a decent job, you could wet sand at 600, spray your base coat, wet sand 800, spray again, wet sand 1000, and spary again, wet sand 1200, buff, and wax....
If your using regular autmotive paint its the same but putting primer and sanding it before the first coat, and then doing clear...
My 0.02
Old Nov 25, 2008 | 06:20 PM
danthemang3's Avatar
hey good luck man now i see why you need my mount lol. on the inside if most of it's going to be covered up i wouldn't worry about sanding like crazy. i never went any higher than 320 on the inside and it still came out decent. i'm having the outside professionally done.
Old Nov 25, 2008 | 06:31 PM
thanks supertuner12010
dan you see in the pic how bad is my mount the prev owner had a h22 and broke the mount
Old Nov 26, 2008 | 07:06 AM
Well the mount is necesarry when putting in an H22,you have to cut it and redrill to accomodate the engine mounts....Im putting an H22 in my hatch, go figure...
And you can get a new OEM chasis mount that you reweld to the body from Honda/Acura
Here is a link showing part number 26, its the mounting bracket that you would need to reweld on. Only $30...Not Bad ayy...
http://www.hondapartsunlimited.com/s...o=%7C025%7C026
Old Nov 26, 2008 | 04:57 PM
thanks superT for the link
Old Nov 27, 2008 | 07:37 PM
Hawkze_2.3's Avatar
Originally Posted by backfromthedead
I have that same DeVilbiss kit and that is not for painting cars. That 2-gun set is around $100 and it is just for hobby stuff and possibly primer. I would not try to paint your car with that. I have shot auto primer with it and it comes out OK, but paint is another story entirely....
I would at least go for a DeVilbiss Finishline 3....at least.
Old Nov 27, 2008 | 07:54 PM
wow man can you please explain a bit more cus this kit have like 2 more different tips is there any differences witch one shawl i get then i have search on ebay and they have different ones
Old Nov 27, 2008 | 07:57 PM
can i just use this
http://cgi.ebay.com/ebaymotors/Devil...motiveQ5fTools
Old Nov 27, 2008 | 08:19 PM
will this ones help i think this is the ones you are talking about
http://cgi.ebay.com/ws/eBayISAPI.dll...3AIT&viewitem=
Old Nov 28, 2008 | 12:45 PM
Hawkze_2.3's Avatar
If you will attempt to read what I posted, you will see that I suggested a DeVilbiss FINISHLINE 3 at least. That is not what you have in those links.
