HOW DO I GET A STAGGERD RIM ON MY EF9
Old Nov 11, 2008 | 09:38 AM
MY EG6's Avatar
Default HOW DO I GET A STAGGERD RIM ON MY EF9
HOW CAN I GET A WHEEL LIKE THIS ONE TO FIT AN EF9 WHAT OFF SET?
Old Nov 11, 2008 | 09:56 AM
CRX Toad's Avatar
Default Re: HOW DO I GET A STAGGERD RIM ON MY EF9 (MY EG6)
ugh...moved from CRX/ EF Forum
Old Nov 11, 2008 | 09:57 AM
kingrye's Avatar
look for e30 and miata wheels
Old Nov 11, 2008 | 02:05 PM
danielg's Avatar
take measurements and do the math.
Old Nov 12, 2008 | 08:21 PM
jdmcivicturbo's Avatar
Default Re: (danielg)
you dont want anything lower than a 15 offset.... but i would recommend like 27.. 15 you have to super duper flare
anything like a 15x8 15 offset. is the lowest, and you dont want a wide tire, 195-50 stretched. if you get 16's you'll have to run 195 40's and they cost bank for those tires
Old Nov 13, 2008 | 08:54 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (jdmcivicturbo)
Stretching a tire onto a wheel that is wider than approved for it is UNSAFE. When you do this, excessive stress and heat builds up in the sidewall of the tire, and can lead to tire failure (blowout, etc). DON'T DO IT.
On a '92-95 Civic, stick to wheel widths that are approved for the proper tire size for your car. The best fitments are 195/50-15 tires on 15x6 or 15x6.5 wheels, or 205/40-16 tires on 16x7 wheels. Stick to those.
jdmgirl90
Feb 2, 2014 08:50 PM
slick702
May 25, 2011 03:16 PM
garyc17
Oct 8, 2010 09:27 AM
Lightsped
Aug 12, 2008 12:10 PM
YipMan_Style
Feb 12, 2008 03:43 PM
