94 coupe mud flap hardware
i called majestic honda and they said that the hardware package couldnt be purchased seperatly from the mud guards. since i just purchased used mud guards without all of the hardware i was wondering what everybody else used to hold the rear ones to the bumper without it looking ghetto.
thanks
thanks
I just installed new oem mudgards (brand new in box and includes hardware! sweet!) on my 92 hatch last night....take one of the screws from the back part of the fender liner on the driver's or passenger's side as a guide for what you'll need to buy at your local hardware store. It should be a black screw with a phillips head about a quarter inch wide(the head part) and about 3/4 inch long. You will need three for each corner. The inner most connections to the fender liner in the rear require one of those small square plugs with the accepting end inside. Other than that you will need small clips that attach to the mud gards themselves that each screw will tap into before going into the fender....I wish I could post a pic, but I'm at work.
good luck..pm me with any other ?'s
I can't reply to my pm's at work because its a dinosauric computer and they don't have flash. But i can read them. the rears are the easiest to install. There should be predrilled holes in the front ends of the rear bumper to accept the mud gards...if you bumper doesn't have this, you might have to drill your own. The third contact point should be inside the fender well and there should already be a screw inside securing the inner fender liner that you can use.
I would take some pics, but my digi is busted. hope this helps
i dont have any inner fenders for the rear of the car. i prolly should get the little thing huh.
i do know where that little square in the rear is though.
xXViperXx
27
Dec 21, 2008 11:17 AM
unknown0001
Nov 9, 2004 10:16 AM
VTEC-DA
Jun 10, 2003 12:56 PM
