d15 no heat/nothing
Old Nov 11, 2008 | 09:26 AM
88ef91r32's Avatar
Default d15 no heat/nothing
hey every1 just bought a winter car, its an 88 civic hatch, d15b2, its got no heat, no blowing, nothing, does any1 have anything for me to check out on it? this is my first honda lol any help is appriciated, thanks!
Old Nov 11, 2008 | 10:34 AM
aptyk88's Avatar
Default Re: d15 no heat/nothing (88ef91r32)
blower motor is behind the glove box hope that helps a little
Old Nov 11, 2008 | 10:57 AM
KRZRICAN's Avatar
check out the fuses...
Old Nov 11, 2008 | 11:13 AM
Black4thgenEF's Avatar
Default Re: d15 no heat/nothing (KRZRICAN)
If the fuse is good, check the blower motor.
If the motor is good, check the resistor.
If the fuses, blower and resistor are good, you might have a wiring issue that you will have to search out.
Old Nov 12, 2008 | 12:09 PM
88ef91r32's Avatar
i checked all fuses, none are blown, i checked the resistor and it seems fine. how do i check the blower motor itself?
Old Nov 12, 2008 | 03:18 PM
Dual Cam Killer's Avatar
Blower motor is the problem guy. Bought a crx this past winter, same prob. Once you get a new one in there, the heat works so good, will run you slap out the car. NO bs. lol
Old Nov 12, 2008 | 04:12 PM
88ef91r32's Avatar
cool thanks, i'll try to pick one up asap then!
Jason Cline
Honda Civic (2006 - 2015)
Jul 9, 2014 05:09 PM
tealej2
Apr 15, 2013 10:08 AM
94trouble
Nov 11, 2010 05:50 AM
LATINOSPEED
Aug 1, 2007 09:06 AM
trey1123
Apr 24, 2007 10:15 AM
