D15B8 block with a D15b7 Head in an 91 Civic Si PLEASE HELP
bet you've never heard of this before. so i'm swapping my engine out cuz the motor was blown and what i have to work with is a d15b8 bottom block out of a 92-95 cx hatch and a d15b7 head out of 92-95 dx hatch. Here's the big question, would i be able to put the d15b8/b7 into an EF Si and keep it OBD0 without any problems?? Or would i have to switch to OBD1 even if its non vtec.
Although not directly related to your question, I'd like to point out something about the B8 since you're using it.
I tried a mini-me on my B8 and found that the water pipe on the back has one less outlet. The reason why is that the CX doesn't have the Fast Idle Valve on the throttle body. This is something you may have to address if you plan on using the B7 throttle body.
BoRiCuA
11
May 27, 2013 12:09 PM
boostedefhatch
27
Mar 8, 2009 02:27 PM
daredeezy619
Nov 4, 2008 10:32 AM
peshte
19
Jun 15, 2005 09:55 AM
Lookincrazy
Jul 30, 2002 06:20 PM
