cx block with single cam si head?
hey guys i just had a question. Can you put a 92-95 si single cam head on a 92-95 cx block? if so how much power will that roughly produce can will it produce as much power as a 92-95 si single cam vtec 125 hp?....thanx.......and please if you dont got an answer to this please dont post....thanx
Sushi Buffet Champion
Re: cx block with single cam si head? (Lookincrazy)
In that case it's not even worth it. Get a D16 block and a "Y" head. And for the tranny get an Si/EX. Don't worry, all of this will run you under $500. If you're not planning to go all out with the DOHC swaps, this swap is well worth the money.
Re: cx block with single cam si head? (GapxGuy)
I already have the cx block and the si head. I am going to put it on. My question was about roughly how much power will it produce and will the si head bolt up to the cx block.........................thanks
I'm guessing about 10HP. Try this is site out, hope it helps.
http://crx.honda-perf.org/articles/z6swap/z6swap.html
[Modified by GapxGuy, 3:25 AM 7/31/2002]
h8tred
18
03-31-2003 02:27 PM
civicracer1993
01-02-2003 08:28 PM
ok , i got a 96 SI head , intake mani ,and throttle Body, what else do i need to go onto my CX block
civicracer1993
01-02-2003 08:27 PM
civicracer1993
12-29-2002 11:09 PM
