help, going from 32mm to 36mm
Old Nov 10, 2008 | 05:44 PM
6Spd_EJ6's Avatar
Default help, going from 32mm to 36mm
I have US ITR 32mm front hubs and would like to go to 36mm hubs. what do I need in order to do this and what car to get them from? thanks in advanced
Modified by 6Spd_EJ6 at 8:29 PM 11/10/2008
Old Nov 10, 2008 | 06:38 PM
Little_Nolan's Avatar
Default Re: help, going from 32mm to 36mm (6Spd_EJ6)
36mm front hubs and 36mm axles/nuts.
Why the switch?
Old Nov 10, 2008 | 06:59 PM
pogeeboy27's Avatar
Default help, going from 32mm to 36mm (boostn92vx)
Get the front hubs and knuckle assembly from a 96+ CRV. They'll bolt right up. Oh and don't forget axles.
Old Nov 10, 2008 | 07:00 PM
BlueIntegraBoy's Avatar
What's the purpose?
Old Nov 10, 2008 | 07:24 PM
6Spd_EJ6's Avatar
Default Re: help, going from 32mm to 36mm (BlueIntegraBoy)
well the reason is I want to use oem type s axles in my car. i have swap axles and they all suck. they all vibrate and leak grease everywhere and so on.. so I would like to use factory axles. would CRV hubs press right in?? dont really want to use the whole spindle.
Old Nov 10, 2008 | 07:26 PM
You need CRV hubs and bearings
Old Nov 10, 2008 | 07:32 PM
6Spd_EJ6's Avatar
from a 96-01 model right??
Old Nov 10, 2008 | 07:33 PM
97-01
Old Nov 10, 2008 | 07:37 PM
6Spd_EJ6's Avatar
thats what I meant.. typo.. but anyway thanks for the help bud.
Old Nov 10, 2008 | 07:38 PM
highroller54's Avatar
I'll trade you a set of jdm 36's for yours, crv knuckles have a diffent casting number then the jdm itr's (I have them both wrote down here somewere). I have seen many people say they have the same part number but I cant see how.
Old Nov 10, 2008 | 07:44 PM
6Spd_EJ6's Avatar
Default Re: help, going from 32mm to 36mm (highroller54)
casting maybe different numbers but the bearings and hub should fit.. but I will let you know
Old Nov 10, 2008 | 07:50 PM
yes crv bearings and hubs will go into a jdm itr spindle. I would like to see a alighnment of a car before and after a crv spindle swap.
zimmy709
Other Make Vehicles
Nov 11, 2008 04:57 PM
flyingduck04
Jan 16, 2004 08:49 AM
jerzeytib
Oct 22, 2003 08:49 PM
