Bad slave cylinder?
Old Nov 10, 2008 | 02:39 PM
TOAB's Avatar
Default Bad slave cylinder?
Finished up putting a new clutch in my 94, and I'm fairly certain I have all of the air bled from the lines. However, I cannot get the thing to go into gear while it's running. I can start it in gear but the clutch is doing absolutely nothing. The arm that moves the throwout is moving.
Do I need to adjust some freeplay, or is the slave actually dead? The only thing that's really messing with me is that it was just fine prior to removing the trans.
Just looking at possible causes to this issue... Hopefully I won't have to crack it all apart again.
Old Nov 10, 2008 | 03:21 PM
02 accord's Avatar
Default Re: Bad slave cylinder? (TOAB)
The slave cylinder is not dead, as it is moving the fork. Is the tranny sitting flush with the block? That's the only thing I can come up with.
Old Nov 10, 2008 | 03:23 PM
TOAB's Avatar
Yes, The trans is already bolted up to the block, and should be flush. The bolts are in, and both of the guide pins lined up... ughh this is killing me.
Old Nov 10, 2008 | 03:28 PM
02 accord's Avatar
Default Re: (TOAB)
The only other thing I can think of is a bent/broken clutch release fork. But if it worked fine before, I don't know why it would be a problem now. Is your new throwout bearing the same thickness as the old one?
Old Nov 10, 2008 | 03:37 PM
TOAB's Avatar
I'm assuming it is... kinda hard to tell with the new one being installed Came in a kit for the car, and it looked to be about right with no blatantly obvious differences.
Old Nov 10, 2008 | 03:42 PM
GlassJAw's Avatar
Default Re: (02 accord)
Could be a bent fork as stated, or the fork may not be fully in the correct place / attached. From memory the clutch fork is attached to the gearbox housing by a spring like wire over a ball joint, if it isnt clipped in place properly it wont have the correct leverage.
Old Nov 10, 2008 | 03:43 PM
TOAB's Avatar
Default Re: (GlassJAw)
Originally Posted by GlassJAw
Could be a bent fork as stated, or the fork may not be fully in the correct place / attached. From memory the clutch fork is attached to the gearbox housing by a spring like wire over a ball joint, if it isnt clipped in plpace properly it wont have the correct leverage.
This is what I was afraid of hearing. The wire on the back of the fork did clip over that knuckle inside the tranny... but it must have popped out with all the jiggling on installation.
Old Nov 10, 2008 | 03:48 PM
GlassJAw's Avatar
Default Re: (TOAB)
I had a similar experience, but from memory I didnt have to remove the box to get it back into place. Just pop off the boot and lever it onto the ball joint with a crow bar or large screw driver.
Old Nov 10, 2008 | 03:57 PM
P_Adams's Avatar
Default Re: (TOAB)
I'd bleed the system just to eliminate that as a problem.
If that doesn't take care of it:
Without disturbing the hose (and without pressing on the pedal), dismount the slave cylinder and see if you can manually move it in the apply direction.
If you can, more than likely the wrong Throw-out bearing was supplied.
Honda lists two for your application:
http://www.hondaautomotivepart...USING
That <U>may</U> be what you're up against.
P
mouab18c1
May 25, 2012 11:07 PM
jaysome01
Sep 5, 2008 01:34 PM
lo0nY
Feb 26, 2006 03:58 PM
johnqt3
Oct 7, 2005 11:05 AM
mdj_ge
Dec 3, 2004 06:45 AM
