i can haz bumpstops
Originally Posted by yc_dc4mar
where can i buy new bump stops? i got some koni's they didnt come with any. my old ones are garbage.
http://www.ground-control-stor...II=10
If you want to tune your bumpstop behavior:
http://www.resuspension.com/Bu....html
wow i thought they were like 5 bucks
ill wait to get good ones when i get my GC and a can do a little research on what i need and all. thanks
You might also consider posting in the classified section, as many people (myself included) are using GC extended upper mounts, and have stock bumpstops just sitting on a shelf somewhere. Mine are only kept in case I decide to put the stock suspension back on, but many won't need to keep them and would probably be willing to part with them for a little over the cost of shipping.
thanks! hey another question..say i go with the ones on GC site... whats the difference between stiff liner and soft progressive?
I imagine that the "stiff linear" have more of a linear curve to the compression resistance (spring rate),and start out stiffer. How stiff? Without a nice graph, it would be a wild guess.
Notice how the other link I posted (with tons of different bumpstops) has graphs showing the rate change under compression.
Progressive (and they look like the GC "soft progressive" visually):
Linear (or more so at least):
Of course, at this point, we're stepping right outside of my knowledge realm.
If you don't know how to tune with the bumpstops, then you can take the approach I do. Consider the bumpstop to be nothing more than a "last ditch safety for the shock", try to avoid much contact with it, and use a progressive stop to minimize the change in car behavior when contact does happen.
Tuesdaynightfever
Jan 9, 2006 02:06 PM
kingkong
18
Apr 25, 2005 11:37 AM
