OBD2 Integra engine harness HELP
I bought a OBD2 integra GSR engine harness from (pwrofdrm) <U>supposedto be uncut but it had some wire cut off </U>
, anyways I now need to find out what wire this is and where does it go. Its a Yellow wire with a green line on it.
that section of the harness looks like it would be for vtec solenoid, starter, and coolant temp sensor( correct me if im wrong ). if im not mistaken there is supposed to be a ground wire there. but i don't think that wire is for the ground. im not sure what its for. gona try to do some research for ya.
bump!
bump!
coolant temperature sending unit wire. Not the coolant temperature sensor, thats 2 wire. But the sending unit that sends the signal to the temp gauge in the gauge cluster.
