stock clutch=light clutch pedal?
Old Jul 30, 2002 | 08:42 PM
Sonnboy18's Avatar
Default stock clutch=light clutch pedal?
i have an 01' gsr with about 20,000 miles on it...for some reason my clutch pedal seems really light...i was wondering if this was normal? i took it to the dealership and ask them about it and they said that it could be that my clutch was worn down and left it at that..dealerships suck ...thanks
Old Jul 30, 2002 | 09:42 PM
mugenracer's Avatar
Default Re: stock clutch=light clutch pedal? (Sonnboy18)
i'm still on stock clutch and mine is fairly heavy, way heavier than VTi civics and prelude Si's
Old Jul 30, 2002 | 10:36 PM
vteg's Avatar
New User
Either your are very used to cable clutch, or your clutch disk has not worn very much. My clutch got heavier as it wore. After I replaced my clutch, my pedal was lighter than my gas pedal.
Old Jul 31, 2002 | 04:50 AM
MrBite's Avatar
There is also a clutch assist spring that helps your foot push the pedal down--that makes it feel a little lighter. If you ever bleed your clutch you can tell since the pedal pulls itself to the floor. Maybe try taking it out if you want a stiffer-feeling pedal. it doesn't really bother me, I only have to move the pedal ~2 inches to shift...
Old Jul 31, 2002 | 08:15 AM
ee-gsr's Avatar
Default Re: stock clutch=light clutch pedal? (MrBite)
my gsr is at 19.3K miles now and the clutch feel has been consistent since day one...which is a bit light IMO. i wouldn't mind a slightly heavier clutch pedal or one that gives a little more feedback.
on a side note, i drove an e46 bimmers a few months back and feel that the bimmer clutch was on par in terms of pressure required, but the e46 has hella long clutch pedal travel compared to the teg...at least 3 inches more of travel.
Old Jul 31, 2002 | 08:25 AM
PM-Performance's Avatar
Default Re: stock clutch=light clutch pedal? (ee-gsr)
al the hydro stock clutches are a little light, i feel weird now getting in my stock 02 si from my itr with the act xtreme press plate and org street disc. . .it takes a few minutes to remmember how to drive the R again . . . and the si i ride the clutch cuz im not used to it being so loose
Kyle244R948
Nov 26, 2008 01:25 AM
Kermit EK
Jan 29, 2003 03:02 PM
97hb
Jan 18, 2003 11:49 PM
