what rim size do i get for 00 civic??
Old Nov 10, 2008 | 10:36 AM
chapagetti's Avatar
Default what rim size do i get for 00 civic??
i know my bolt pattern is 4x100. is that all i need?
Old Nov 10, 2008 | 10:39 AM
hard_boiled_EG's Avatar
Default Re: what rim size do i get for 00 civic?? (chapagetti)
you can have whatever you like...
Old Nov 10, 2008 | 10:46 AM
EJ8_Enthusiast's Avatar
yeah, also look at offset (you want around 40 to 45 I believe, check the faq) and you will most likely want to do 15 or 16 inch - check the faq again for optimal tire size..
Old Nov 10, 2008 | 10:48 AM
BEE1's Avatar
Default Re: (EJ8_Enthusiast)
15s if you want to be functional
16s if you want to stunt
Old Nov 10, 2008 | 10:59 AM
sintype's Avatar
any size you want.
Old Nov 10, 2008 | 11:45 AM
BlackDeuceCoupe's Avatar
HT White Ops
14" & 15" OEM alloys (made by Enkei) look nice e.g. '96-'00 HX 14" & '99-'00 Si 15" - not ricey at all!
I have both, but prefer the 14" HX alloys (11.75 lbs vs 18.0 lbs): https://honda-tech.com/zerothread?id=1252875
Personally, the only other rims I would consider is 17" Rota Slipstreams - something like that.
If you want your speedo to work (show the correct speed) and don't wanna roll your fenders (rubbing problems)...
Tire sizes: 185/65-14 -- 195/55-15 -- 205/40-17
Old Nov 10, 2008 | 11:46 AM
93egSLEEPER's Avatar
IMO nothing bigger then 16
Old Nov 10, 2008 | 12:35 PM
drave's Avatar
Default Re: what rim size do i get for 00 civic?? (93egSLEEPER)
If you live with crappy roads, go with a 15'' wheel with a 195/50/15 tire or a 205/50/15 if you don't want to tuck tire. If you live with nice roads, go with a 16'' wheel with 205/45/16. If you live with REALLY nice roads, go with a 205/40/16. Do not go with anything bigger than a 16'' wheel.
Old Nov 10, 2008 | 01:24 PM
chapagetti's Avatar
thanks for all the great advice everyone. i know a lot of tuners are against getting bigger than 16 inch wheels on hondas.. i kinda want to get 17 inch tho. i was thinkin white enkei rfp1 17" 4x100 to match my white 2000 civic hb. so offset 40-45? heres another question.. what makes it okay for some cars to get 17's but not my car? does it have to do with horse power? not that it is but, if got my car up to 500hp, would that make it okay to have 17 inch wheels? oh and btw, the roads by my house are nice, and its only a 2 min commute to work, literally. so basically its a daily driver but it will be driven approx 4 min every day. lol im not too worried about pot holes and that sorta thing
Old Nov 10, 2008 | 01:26 PM
chapagetti's Avatar
oh and for tire sizes, what are the three numbers referring to? 195/50/15...? the last number is the rim size by inch im guessing.. what are the first two numbers? thanks
Old Nov 11, 2008 | 01:15 PM
HT White Ops
Default Re: (chapagetti)
http://www.discounttiredirect....s.jsp
Old Nov 11, 2008 | 01:16 PM
yoontim23's Avatar
stick with 15"
vegaskurt
Feb 8, 2005 05:18 PM
BDogggUT34
Dec 6, 2004 08:13 AM
JAI-DM
May 12, 2004 09:47 PM
1hotcivicSi
Feb 19, 2004 01:14 PM
PBTemplar
16
Sep 23, 2002 08:18 AM
