Does anyone know if the 96-98 sohc engine is an iterference head?
Old Nov 10, 2008 | 06:54 AM
lsvtecturbosol's Avatar
Default Does anyone know if the 96-98 sohc engine is an iterference head?
I am pretty sure it isn't because Ive broken a timing belt before on mine and it didn't bend or break anything but I have a friend that just broke hers and before she spends a lot of money to replace it I want to be 100% sure that it isn't interference.
Thanks in advance for any help.
Old Nov 10, 2008 | 07:08 AM
v8 integra's Avatar
ive herd that most 4 banger hhonda engines interfere....bump for more info
Old Nov 10, 2008 | 07:47 AM
hatchling37's Avatar
Default Re: (v8 integra)
It's definitely an interference engine.
Old Nov 10, 2008 | 08:35 AM
Default Re: (hatchling37)
Damn I guess I just got lucky with mine then.
Old Nov 10, 2008 | 09:12 AM
NOFX's Avatar
H-T White Ops
Default FV-QR
Definitely interference. Something like 95% of Honda engines are interference.
This is why it's always stressed to replace the timing belt if it's time or if you don't know if it's been replaced.
Old Nov 10, 2008 | 09:53 AM
Default Re: FV-QR (NOFX)
I know that all the B, H, F, and K series motors are and that most of the NON vtec D series are NOT but I wasn't sure about the vtec D's
Old Nov 10, 2008 | 10:25 AM
NOFX's Avatar
H-T White Ops
Default Re: FV-QR (lsvtecturbosol)
No, those are all interference.
Old Nov 10, 2008 | 03:49 PM
Ok thanks then. I guess I just got lucky as hell with my old crappy single cam. I've always neglected D motors because they don't cost to much but my B series motors always have been well taken care of. Haha I ran my D into the ground just to come up with a reason to buy a b16 swap.
Thanks for all the help I guess I will tell her to have it taken apart and see if she bent anything.
Old Nov 10, 2008 | 04:13 PM
Frost7177's Avatar
it's a interference motor make sure you replace to timing belt like everyone else said
Old Nov 10, 2008 | 05:06 PM
The_Honda_Guy's Avatar
The D15 may not be. My brother in law's 95 D15 non-VTEC snapped the timing belt and didn't bend any of the valves. There's not many motors that are non-interference.
Old Nov 10, 2008 | 05:30 PM
z6hatchboy's Avatar
i think they are, i had a b7 that snapped a belt once, and bent valves. But then again, b7 pistons are flat and z6 pistons are dished
Old Nov 10, 2008 | 05:44 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: (The_Honda_Guy)
Originally Posted by The_Honda_Guy
The D15 may not be. My brother in law's 95 D15 non-VTEC snapped the timing belt and didn't bend any of the valves...
AFAIK all Honda motors are 'interference' motors!
Gates says all '95 D15s (CX, DX, LX, VX) are 'interference' motors... Your brother-in-law just got lucky!
If anybody wants to check their motor: http://www.gates.com/part_loca...=3598
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The vehicle shown is not an interference engine unless noted "Interference Engine Application" in the comments column of the Cam Belt application section.</TD></TR></TABLE>
Old Nov 10, 2008 | 06:14 PM
Wow, he got super lucky then. Are the Honda engines firing orders 1 and 4 together, then 2 and 3 together? If so, I guess you have a better chance of not smashing the valves. Also, I guess it depends on how big of a lift and duration the stock cam has. If it's pretty small, you've got an even better chance then.
Old Nov 10, 2008 | 06:42 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
Just because there have been X type of engines in the past which have snapped timing belts and been fine doesn't mean they're not interference.
I believe all D-series engines are interference.
Old Nov 10, 2008 | 06:52 PM
Mill-Town's Avatar
All honda motors are interference motors. The only sohc an dohc motors I know of that arent interference are mazda's kl's
Old Nov 10, 2008 | 07:40 PM
zero708970's Avatar
If you guys want more info....
http://www.tegger.com/hondafaq...rence
Old Nov 10, 2008 | 08:42 PM
BWek's Avatar
H22A is a non interferance motor My friends Auto tensioner went on the motor and i turn the motor over and not hit any valves
Old Nov 11, 2008 | 12:34 AM
HT White Ops
Default Re: (BWek)
Originally Posted by BWek
H22A is a non interferance motor...
Fail...
Old Nov 11, 2008 | 02:33 AM
Got traction's Avatar
a d series with a vitara build and normal eagle rods becomes a non interferance motor
BLKFLSH
Jan 21, 2018 01:16 PM
bempieman
Jun 2, 2017 07:16 PM
1sic95accord
Nov 3, 2016 02:55 PM
boostin4door
Mar 9, 2004 07:13 PM
