d16y7 question
Old Nov 9, 2008 | 11:31 PM
thebleek's Avatar
Default d16y7 question
Hey i picked up a d16y7 because my old one had rod knock. Well not knowing i bought one that was from an automatic. My car is a manual. Will this work?
Old Nov 10, 2008 | 01:36 AM
z6hatchboy's Avatar
It'll work, just replace the flex plate on it with your fly wheel and your good to go. I've done this before
Old Nov 10, 2008 | 01:46 AM
thebleek's Avatar
it wont start for some reason. sounds like the symptom of a dead battery/low voltage. but then again my car has been sitting for 2 months. We hooked up the jumper cables for 15 min and it still wouldnt start.
im using the dizzy from a d16y8 but that doesnt matter right?
Old Nov 10, 2008 | 04:33 AM
94EG8's Avatar
Seagull Management
Default Re: (thebleek)
As long as it bolts up to the head it'll work fine.
Old Nov 10, 2008 | 04:38 AM
wrenchez81's Avatar
Default Re: (94EG8)
does it even crank when u try to boost it or it now cranks but wont start??? did you check ALL power and grounds....
Old Nov 10, 2008 | 02:40 PM
thebleek's Avatar
Default Re: (wrenchez81)
boost it??
i checked all power and grounds
it cranks just wont start...sounds like it had low voltage
thyshallsmite
Oct 7, 2013 02:36 PM
Cav3man
14
Mar 23, 2012 06:37 PM
CRXguy_88
Feb 22, 2012 07:49 PM
WTB AUTO EK
Jul 5, 2005 11:05 AM
99eciVic
11
Aug 16, 2004 08:41 PM
