what should i do about this rust ?
Old Nov 9, 2008 | 04:08 PM
jdubb7's Avatar
Default what should i do about this rust ?
i have rust on both quarter panels & then down by the back door, how do i get rid of it ?
& also what would be the best green for a eg 4 door ? THANKS IN ADVANCE
Old Nov 9, 2008 | 04:15 PM
jdubb7's Avatar
anybody ????
Old Nov 9, 2008 | 06:07 PM
boostedtsi's Avatar
well your going to need to sand the rust off to begin with. Till then you do not know how bad the bubbling actually is.
The one that already has a hole, your going to need to do a patch panel. Same with the other two if they are all the way through.
Old Nov 9, 2008 | 06:21 PM
HighRevn's Avatar
Default Re: (boostedtsi)
Cut out all the rust and weld in new spot panels.
Old Nov 9, 2008 | 07:41 PM
jdubb7's Avatar
any other suggestions ???
Old Nov 9, 2008 | 11:38 PM
Sic_DA_Nine's Avatar
cheap and easy way..
this is IF thats all the rust there is..
sand/grind off all rust..
for the one with the hole, use fiberglass for the backing and body filler to clean it all up.
then paint
Old Nov 10, 2008 | 08:37 AM
katzenjammer84's Avatar
Permanent solution: New 1/4 panels
Temporary solution: Patch panels
Old Nov 10, 2008 | 12:15 PM
jdubb7's Avatar
thanks for the info, any other suggestions guys. anybody know what color i should go with, im trying to stay with the green just a different shade
Old Nov 11, 2008 | 12:19 PM
jdubb7's Avatar
Old Nov 11, 2008 | 09:18 PM
Pandahatch's Avatar
Default Re: (katzenjammer84)
How is a welded in patch panel a temporary fix? Vague statement there...
Check out:
http://www.rustrepair.com
http://www.fixmyrust.com
They sell replacement wheel arches. They're perfect for what you need. If you don't have experience cutting, welding and doing body work, you may want to find someone who does, Honda metal is VERY tricky to weld properly and not warp/burn through. Stay far far far away from fiberglass garbage.
Old Nov 12, 2008 | 12:32 PM
jdubb7's Avatar
thanks for the help
Old Nov 12, 2008 | 10:43 PM
LoSt is BlaCk's Avatar
Default Re: (jdubb7)
welcome to the rust club...
Old Nov 15, 2008 | 02:35 PM
SpeedSin's Avatar
Yeah rust sucks. I had a couple of spots a few years back and I just sanded all the rust of and used a little body-filler and painted. Havent had any rust issues since. It has held up well.
EKSedAndy
Paint and Body
Mar 11, 2009 06:42 PM
ludesrv
Mar 2, 2007 09:59 AM
civiceg500
Dec 10, 2004 12:17 PM
4inspeed
15
Aug 23, 2003 02:54 PM
IS3Fifty
Feb 20, 2003 06:50 PM
