Steering wheel from '96-'00 Civic into '92-'95 civic?
Old Nov 9, 2008 | 03:32 PM
imzjustplayin's Avatar
Default Steering wheel from '96-'00 Civic into '92-'95 civic?
I was wondering if it was possible to put the steering wheel from a 1996 civic into a '92-'95 civic. I'd expect the horn and air bag to function as they would from the car they came from. The reason I want to do this is because they depowered the airbags in 1996 because earlier airbag implementations were designed with unstrapped people in mind while the '96 has strapped in people in mind, i.e less force.
Old Nov 9, 2008 | 05:07 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
I believe they actually de-powered the airbags in '97 or '98.
The wheel won't fit though. Different number of splines on the column IIRC.
Old Nov 9, 2008 | 05:53 PM
z6hatchboy's Avatar
Default Re: Steering wheel from '96-'00 Civic into '92-'95 civic? (imzjustplayin)
^ dont listen to her she has no idea what shes talking about haha (before i get flamed read the rest lol). Actually she knows just about everything, in a good way. Especially on the oem parts, keep it up
Old Nov 9, 2008 | 05:57 PM
Default Re: FV-QR (NOFX)
I don't want to sound like an *** or anything, but comparing these two pictures, it looks like where you hook up the wheel has the same number of teeth, if that is what you're talking about.. ?
http://importnut.net/civicsteeringswap.htm
http://www.jdmuniverse.com/for....html
Old Nov 9, 2008 | 06:35 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
I can't even tell how many teeth are on each of those from those photos.
Everyone always points out they have different numbers of teeth though. This is why certain wheels fit on 6th gens, but not 5th gens.
You can go ahead and try it out though. Buyer beware of parts that won't fit.
Old Nov 9, 2008 | 06:44 PM
NOFX's Avatar
H-T White Ops
More info.
https://honda-tech.com/zerothread?id=2413230
Too bad search is still all funny. I had to use Google instead, and it brings up broad results by comparison.
Old Nov 9, 2008 | 06:54 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
https://honda-tech.com/zerothread/1851439
Originally Posted by Eran
The following wheels will fit on a 96-00 Civic:
S2000 (AP1)
S2000 (AP2)
Insight
RSX
RSX Type-S
Civic Si (EP3)
Civic Type R (EP3)
Integra Type R (DC5)
Honda Integra (DC5)
Prelude (BB6)
The Following Will Have Working Airbags:
Civic Type R (EP3)
S2000 (AP1)
Integra Type-R (DC5)
Insight
Prelude (BB6)
Not sure about any of the other JDM wheels, don't recall if they have single or dual deployment.
Originally Posted by 369 EG6
hey thats a noce looking wheel i had never thought of that but think that the s2000 one looks better. im thinking on my EG6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Too bad it won't work on your steering column. None of the wheels listed in this thread will.</TD></TR></TABLE>
Eran goes over more here, stating that 8th gen wheels will fit 6th gens, but not 5th gens.
https://honda-tech.com/zero...30495
Old Nov 9, 2008 | 07:22 PM
jime64871's Avatar
nice and precise info.
You could change the steering shaft from the donor car as well, but that's a lot more work.
Old Nov 9, 2008 | 09:15 PM
jeffnerette's Avatar
the wheel itself wont fit but if you change the column and wheel then it would fit. that how i put my s2k steering wheel in my car.
Old Nov 9, 2008 | 11:59 PM
Default Re: Steering wheel from '96-'00 Civic into '92-'95 civic? (jeffnerette)
Did you have to replace the rack and pinion? Rebuild it? Is it separate? How much work was involved? Any guides that you could direct me to that may indirectly involve removing/adding the column? Would this be the same as adding tilt steering to a Civic VX which is the only civic not to include it?
Old Nov 10, 2008 | 01:29 AM
i have no links to it but it was pretty easy. on the difficulty scale i would probably give it a 4. [QUOTE= Would this be the same as adding tilt steering to a Civic VX which is the only civic not to include it?[/QUOTE]
exactly swap the column by separating it at the spline by the pedals. hope this helps.
Modified by jeffnerette at 2:37 AM 11/10/2008
techtuner
Northwest (Sales)
Dec 23, 2008 06:09 PM
KeyserSoze
May 12, 2008 07:13 PM
CTRwannaB
Mar 20, 2008 06:29 PM
jc2801
Jun 19, 2007 06:35 AM
SloAssHB
Jan 20, 2007 09:12 AM
