someone please help!!
Old Nov 9, 2008 | 03:05 PM
boostedekhatch's Avatar
Default someone please help!!
ok so for some reason my car wont keep a charge it has a new alternator and a bettery but it still dies out after awhile, its a obd1 ls into a 2000 civic???
please let me know this is frustrating.thanks
Old Nov 9, 2008 | 07:29 PM
LA_HONDAS's Avatar
Default Re: someone please help!! (boostedekhatch)
check the fuse under the dash
Old Nov 9, 2008 | 07:46 PM
i checked them they look fine...??
Old Nov 9, 2008 | 07:49 PM
LA_HONDAS's Avatar
Default Re: (boostedekhatch)
start the car up and unhook the batt... and see if it dies
and did you check the fuse under the hood
Old Nov 9, 2008 | 08:11 PM
kiba's Avatar
you can always use a voltmeter on the battery while the car is off and running to see if its charging.... check the connections on the back of the the alt....
Old Nov 9, 2008 | 08:37 PM
ya i checked the battery fuse under the hood it looked fine also..???the car doesnt die out when i un plug the battery but the alt and battery are new i just put them in???but when i turn the lights and stuff on then thats when the rpm stops working and the radio gets twacked out..also my speedometer stopped working when all this started happening
Old Nov 9, 2008 | 08:40 PM
LA_HONDAS's Avatar
is the alt obd1 or obd2?
Old Nov 9, 2008 | 08:42 PM
its obd1
Old Nov 9, 2008 | 08:52 PM
LA_HONDAS's Avatar
try and hook up just the black/yellow wire on the alt to a key on 12v and see if it run with the batt unhook
or take a voltage meter and see if the black/yellow on the alt is getting 12v when the key is on
djrubio
Jul 18, 2009 07:41 PM
Tip14
Dec 27, 2007 01:13 PM
R-81DC2
Jun 5, 2007 09:21 AM
antiricer
13
Jan 20, 2007 02:52 PM
WAT THA!!!
Oct 8, 2004 01:08 PM
