NEED HELP.....2000 B18C1 FOR TURBO
Old Nov 9, 2008 | 11:39 AM
dc-2z's Avatar
Default NEED HELP.....2000 B18C1 FOR TURBO
HI I AM NEW AT THIS I HAVE A 2000 GS-R I CURRENTLY SEPERATED MY BLOCK AND HEAD BECAUSE I WANT TO TURBO MY WHIP IM LOOKING TO GET 500 HP I NEED SOME HELP AND SUGGESTIONZ ON WHAT SLEEVES WHAT CAMS AND SO ON SO IF U HAVE ANY ADVICE PLEASE HELP ME OUT HERES A PIC OF MY TEGGY http://www.cardomain.com/ride/2964995
Old Nov 9, 2008 | 11:49 AM
sh4mr0ck's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (dc-2z)
I had a topic open just like this... here's the link:
https://honda-tech.com/zerothread?id=2423670
Old Nov 9, 2008 | 11:55 AM
Jimmy's Avatar
Global Moderator
Your best bet is going to be searching and doing alot of research.. and browsing the forced induction forum..
dc-2z's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (sh4mr0ck)
thankz alot buddy
Old Nov 9, 2008 | 12:01 PM
dc-2z's Avatar
yeah thats true........i have read some forum saying a usdm b18c1 can handle up to 400 hp with out sleeving but i rather sleeve it and be on the safe side im thinking of darton sleeve i shoped around i got a quote of $1200 would any one suggest me somethign else
Old Nov 9, 2008 | 12:09 PM
racebum's Avatar
the problem with the stock block isn't in the first week or two provided you don't go lean on the cast pistons. the problem is cylinder walk. the more HP you make the more stress is placed on the block and the inner liners will warp and end with a leaking head gasket. 18c motors do this across the board and are one of the major causes of these leaking headgasket threads people start. boost just adds to the problems. if you really want to make a ten second car you better have a bankroll and the first thing i would tell you to buy is the dart block. now you have a block that can handle serious hp and also more displacement.
Old Nov 9, 2008 | 04:51 PM
dc-2z's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (idrivesideways)
so basacally block wise i should go with darton sleeves
Old Nov 9, 2008 | 04:57 PM
JRSC01GS-R's Avatar
golden eagle or erl or laskey racing are the only places I would ever send a block to for sleeving. 1200 is about right for sleeving a block if u send em a core, some places are a little cheaper, but any of those guys will set u up with a block that will take 800+hp
Old Nov 9, 2008 | 05:20 PM
racebum's Avatar
no, a dart BLOCK, no sleeves involved
if you do sleeves they will cost a little less than the dart block and the post above me explains where to go.
Old Nov 9, 2008 | 05:32 PM
dc-2z's Avatar
what do you mean by dart block exacly
Old Nov 9, 2008 | 07:15 PM
slaminsam's Avatar
http://www.dartheads.com/produ....html
Dart block. For the power you are after I would just get it sleeved though.
Old Nov 9, 2008 | 07:30 PM
DB8GS-R's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (slaminsam)
i ended up running darton wet deck sleeves, je 9:1 pistons, eagle rods w/arp 2000 studs, and an eagle 4130 crank. Stock bore and stroke. Brand new gs-r head with type r cams, aem cam gears, and a healthy bit of p&P work on the head.
Old Nov 10, 2008 | 06:22 PM
dc-2z's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (DB8GS-R)
wa would u guyz suggest ofr intake like wa kind of intake should i go with cause the one o ihave its from a 2000 gs-r
Old Nov 10, 2008 | 06:46 PM
90tegblueonblack's Avatar
why spend all the money boosting a motor that already has a 10.6 compression
you won't be able to push much boost without throwing a bearing, or walking your crank
your call, but i would def bore it out and use almost everything else stock
Old Nov 10, 2008 | 06:57 PM
dc-2z's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (90tegblueonblack)
so wat are u suggesting me to do
Old Nov 10, 2008 | 07:26 PM
it is really up to you, i am merely suggesting if you don't have a lotttt of money to tune your c1 perfect, compression checks, boring, fully built bottom end, etc. you won't push much psi
if you want to do all that cool, even if not and boost it but you won't have much boost without walking your crank
i would suggest, skunk2 intake, itr throttlebody, fuel rail, stock injectors, msd ignition, headers full straight pipe, nice clutch, full gut, weight drop, and a shortthrow, not too expensive, worth it, and gets the job done
Old Nov 12, 2008 | 04:57 AM
dc-2z's Avatar
im down to walk my crank i abosouloutly need 500hp LoL .....ur sayng skunk 2 intake iz better then my stock one right?
Old Nov 12, 2008 | 05:21 AM
HondaKyle's Avatar
If you have to ask the question you are not ready for a 500 horse car of any matter. I really hope you didnt do this to an Integra... Why would you put this as your homepage?! This has to be a joke.
Old Nov 12, 2008 | 05:39 AM
projectac's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (HondaKyle)
lol
Old Nov 12, 2008 | 03:14 PM
dc-2z's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (projectac)
first off all i would liek 2 ask question 2 b on da safe side....2nd daz juz picz of ma car u must b a dumb *** 2 talk ****... if u dun wana help jus shut ur mouth daz all i ga oder ppl here dat are helping me out an i do appriciate their commentz and it is use full for me so go F%C* ur self buddy
Old Nov 12, 2008 | 03:29 PM
paton5g's Avatar
No no, how about you go F#ck yourself buddy. Take your mutilated Integra and your awful typing skillz elsewhere. Your asking questions that you could answer yourself by using the SEARCH feature. Furthermore, a 500 hp car shouldn't be anywhere near you if you have to ask what a Darton block is.
This site is for people with common sense. Another requirement is the ability to use a keyboard.
Get lost.
Old Nov 12, 2008 | 03:30 PM
steveo135's Avatar
What do you need to know? It seems kinda like your just ranting about how you need 500 hp. As far haking 500 hp yes the S2 IM is better than a stock GS-R IM... What I don't understand is how you "have" a decked out showcar, but have no clue as to how to build an engine...
Old Nov 12, 2008 | 03:49 PM
SoTexDC2's Avatar
This is totally false information.
First off, you don't have to worry about "walking your crank" as this person is claiming. Are you from the DSM world by chance?
Second, PSI doesn't mean ****. Pick the right size turbo for your goals, and push it to whatever PSI it takes to get there.
I'm done correcting his BS..
The need to sleeve at your power level is debatable, but personally I would sleeve for anything above 450whp. Golden Eagle is one of the most reputable places to go. 81.5mm-82mm bore is perfect for your setup. Run some type of forged piston, CP is my choice, Weisico is another great option. Run forged rods like Pauter, Eagle, etc. Rebuild everything else with OEM parts - oil pump, water pump, main and rod bearings, gaskets, seals, etc. As for headwork, if you have the money then get a standard port and polish, ITR or CTR cams work wonders for your goals. You can also look into Skunk2 cams. Run an Eddlebrock Intake Manifold. Don't forget a clutch to support your increased power level. And TUNE TUNE TUNE! Tunning is everything!
If you need other information, visit the Forced Induction Forum.
Old Nov 13, 2008 | 06:35 AM
dc-2z's Avatar
Default Re: NEED HELP.....2000 B18C1 FOR TURBO (SoTexDC2)
thank you very much....i do know how to build a motor i juz wanted 2 know whats good out there like brand wise now i can get started
Old Nov 13, 2008 | 07:50 AM
HondaKyle's Avatar
I cant even read that, please some what proper English. Your are gonna need to build your motor and get suspension components.
Full race turbo kit $5,151
darton sleeved block $1,000
wesco pistons $535
egle rods $150
ACT Xtreme Sprung - $512
Driveshaft Shop axles $370
Koyo Radiator $401
AEM EMS - 1,500
Valve Springs and Retainers - $341
Thats not every thing you need, I didnt look for a boost solenoid, gaskets, full injectors, fuel rail, fuel PSR, GM map sensor and wheel studs because with 500 you will brake the stock ones. I didnt list EVERY thing but you will need more. All those parts are 9960 give or take a few hundred.
http://www.full-race.com/catal...5cf6a good luck on your build, I think the money would be better spent going to school.
Modified by HondaKyle at 8:59 AM 11/13/2008
