Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
hondata ecu in street touring
Old Jul 30, 2002 | 06:41 PM
solo-x's Avatar
Default hondata ecu in street touring
i'm concerened about the legality of this ecu upgrade. the external interface box maybe violates the "contained in the factory black box" clause??? thoughts??
more info: 93 ex, p28 ecu, stage 2 upgrade
[Modified by solo-x, 3:42 AM 7/31/2002]
Old Jul 30, 2002 | 07:13 PM
jasyatz's Avatar
Default Re: hondata ecu in street touring (solo-x)
Confusing, much like the MSD thing
17.10 line #1 A reprogramed ECU may be used in the standard housing
17.10 line #2 Electronic components may be installed in-line between the ECU
and engine sensors.
Try it out and see what happens, then the rule would get clarified...
Old Jul 30, 2002 | 07:55 PM
Todd00's Avatar
I said I don't want a title!
As long as it doesn't replace your entire ECU, I thought any piggyback unit was fine.
Old Jul 30, 2002 | 08:44 PM
Crack Monkey's Avatar
The extrernal interface is not inline between sensors and ECU, so it is illegal. However, we had this discussion a few weeks ago in this forum - try a search. COntact Hondata - apparently some people have managed to package the interface into the ECU housing or remove it.
Old Jul 31, 2002 | 05:16 AM
solo-x's Avatar
Default Re: hondata ecu in street touring (Todd00)
that's what i thought as well.
an expensive way to clarify the rules. plus i'm hoping to trophy at topeka and would be really bummed if i did but lost it cause of a protest.
Old Aug 1, 2002 | 07:09 AM
Watkinsm3's Avatar
Slightly off the subject, not too much... I was just wonder if Hondata was legal in street prepared? Problems with changing VTEC points?
Old Aug 1, 2002 | 08:01 AM
Default Re: hondata ecu in street touring (Watkinsm3)
In Street Prepared, fuel and ignition are free, so the Hondata is ok. As are any of the other standalone ECUs (Motec, Electromotive, etc).
Old Aug 1, 2002 | 08:21 AM
Watkinsm3's Avatar
Default Re: hondata ecu in street touring (Crack Monkey)
Does this include VTEC adjustment? Not sure about the "Mechanical equivalence" part... This car will, and already does, compete (not very well ) on a national level. So I'd like to be 100% certain on the vtec adjustment side of things. Thanks...
Old Aug 1, 2002 | 09:12 AM
PseudoRealityX's Avatar
Full Stand Alones, including Hondata systems are illegal. This WAS clarified in Fastrack. Vtec controllers ARE allowed in STS.
Old Aug 1, 2002 | 09:34 AM
Tyson's Avatar
Default Re: hondata ecu in street touring (PseudoRealityX)
can you bring up this fastrack? should be on the scca website.
vy3tnamezz
Engine Management and Tuning
Sep 20, 2009 10:43 AM
trick_db
Apr 30, 2006 09:10 AM
straightline
Nov 13, 2002 06:52 AM
