Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Master Window switch problem 2005 Pilot
Old Nov 9, 2008 | 08:30 AM
msnewman's Avatar
Default Master Window switch problem 2005 Pilot
When using the master window switch on my '05 Pilot, all windows operate properly, but when I use the one-push option on the driver's window for "all the way down" or "all the way up" the window only moves when my finger is still pushing the switch. Is this a bad switch? I just noticed this after having a new battery installed. I can't imagine they are related, but it's the only thing that has recently happened with it.
Old Nov 9, 2008 | 09:06 AM
Ross 2.0's Avatar
In a Junkyard near you.
You need to re-program the switch. I think that one only has auto down. So all you have to do is roll the window down and hold your finger all the way down on the switch for two seconds. If it has auto up too you roll it all the way back up and hold for 2 seconds too.
Old Nov 9, 2008 | 09:26 AM
msnewman's Avatar
Default Re: (Ross 2.0)
That was it! Thanks. fyi..the engine had to be on, and this car does have auto up and down.
Old Nov 9, 2008 | 10:11 AM
Ross 2.0's Avatar
Default Re: (msnewman)
You just have to turn they key on. I thought that went without saying. My bad.
Old Nov 9, 2008 | 10:42 AM
msnewman's Avatar
I did have the key on, motor off at first. It did not work, so I started the car, and then it worked. Again, thanks...I was starting to wonder if the switch fried.
EndlEEsss
Feb 23, 2023 03:46 AM
einzelherz
Aug 26, 2013 06:41 AM
TahitianEG
Apr 7, 2011 11:50 AM
accordredliner
Sep 25, 2005 02:34 PM
luder22
Oct 22, 2004 09:19 PM
