P1362 99 Civic EX
Old Nov 8, 2008 | 02:58 PM
TriumphedCivic's Avatar
Default P1362 99 Civic EX Help Please?
Hello everyone. I was told that this site can help me with some of my issues i am having. I recently bought a 99 Civic EX 5sp with a Z6 head and Y8 Internals (rockers, camshaft/gear) and the CEL was on. I took it to Autozone to get some codes read and i had 3.
P1362- Ignition system/Misfire
P1362- TDC Sensor
P0505- Idle Air Control Valve Malfuncion
I checked the timing on it and it was off. So i redid my timing and swapped out my IACV to a known working one and bought new plugs and wires. I then went back to AutoZone and had my CEL cleared out.
Car went strong and great for about 3 miles. I got home and parked the car. About 1hr later i went and started it the CEL came on. I took it back to AutoZone and i have 1 code left which it's P1362.
Symptoms - Car has a hard time starting, but it will eventually start. Hesitation/misfiring.
Im thinking that i need a new Crank Angle Sensor but wanted to make sure before i bought one. Any help would be appreciated.
Thanks in advance.
Old Nov 8, 2008 | 04:57 PM
z6hatchboy's Avatar
try switching out the distributor with a known working one and see if that fixs it. Thats where those sensors are at
Old Nov 8, 2008 | 08:29 PM
I got a used dizzy coming in. I went home today and looked through the garage. Apparently my brother has a y8 block sitting around, low and behold there's a Crank Angle Sensor sitting there. So after the dizzy swap and if that doesn't work i guess i'll have to do the CAS. GOODLUCK to me!
Old Nov 9, 2008 | 05:52 PM
I went to autozone and forked up the money for a new dizzy. It ran good for a while with no CEL then maybe about 3 hours later the CEL came on after i punched it in 3rd gear. Went back to autozone and hoped it wasn't a P1362. Luckily it wasn't, it was P0505- Idle Air Control Malfunction. The IAC that i put in from my brothers 95 hatch mustn't be working. So im on the lookout for a new/working IAC. Anyone here selling one?
Old Nov 9, 2008 | 05:57 PM
z6hatchboy's Avatar
Default Re: (TriumphedCivic)
try the marketplace here, or ebay possibly, maybe even your local junkyard
SJRhino
10
Mar 23, 2016 03:59 PM
eghatch9295
18
Jul 23, 2015 05:36 PM
ChelseaJean
May 9, 2015 08:20 PM
