ls swap bogs at 3000rpm and shuts off
Old Nov 8, 2008 | 02:55 PM
hiphop23j's Avatar
Default ls swap bogs at 3000rpm and shuts off
i just swapped in a b18a in my 96 ek, it starts up and everything stays on but soon as i press the gas it revs up to 3000 rpm and shuts off or bogss out crazy and tries to cut off, im using a step down to obd1 ls ecu, everything stock wat might be the problem, and also i bought a gasket for the tb cuz i thought it might be that but for some reason the only gasket thats fits the tb is the h23 gasket idk why.
Old Nov 8, 2008 | 08:22 PM
hiphop23j's Avatar
Default Re: ls swap bogs at 3000rpm and shuts off (hiphop23j)
help!
Old Nov 8, 2008 | 09:31 PM
helldriver88's Avatar
so your using an OBD1 PR4? if the motor is a B18A1 thats originally obd0 so when swapped into your originally obd2 car...what engine harness did you use??
OBD: on board diagnostic system. your car has a way of telling you something is [freak]ed up. your Honda manual will explain to you how to check it and what each code detects.
Old Nov 9, 2008 | 03:43 AM
hiphop23j's Avatar
Default Re: ls swap bogs at 3000rpm and shuts off (helldriver88)
im using obd2a harness everthing pluged up except the two prong senser on the block
Old Nov 9, 2008 | 07:17 AM
then thats the problem. wrong wire harness. even if the plugs are the same they are wired up differently. you need a OBD1 b18B1 engine wire harness if your wanting to keep using the obd1 B18B1 ECU. your ecu isn't picking up ****. your ecu is programmed with an override / backup computer and even with that its struggling to even simply start up. you want to get an OBD1 B18B1 engine harness asap (1994+ DC4 Integra). that should do it.
Old Nov 9, 2008 | 08:54 PM
hiphop23j's Avatar
but that integra harness wont fit on the ek obd2 style one clip piece being that it goes directly to the ecu and the integra has a 3 piece clip style. it starts up fine revs to 3 grand dies or dies soon as you give gas but if you leave it it stays on fine.
Old Nov 10, 2008 | 01:48 PM
hiphop23j's Avatar
i checked the codes its only throwing a iac valve code but it was always doin that since i never changed that, they said it might be a vacume leak, can it be off timing, but it starts first turn of the key no hesatation
miamihonda
Dec 27, 2013 01:33 AM
lejeaune
Apr 21, 2010 09:31 AM
Sinner
Feb 6, 2006 06:54 AM
