Which B16 is easiest to swap into 98 EX?
Old Jul 30, 2002 | 05:36 PM
MikeMAN's Avatar
Default Which B16 is easiest to swap into 98 EX?
with a 1999-2000 from what i understand is a B16A2..which is supposed to be a pretty straightforward swap...
and then the 2nd gen 92-95 JDM B16 swap.............
which would be easier???
thanks,
mike
Old Jul 30, 2002 | 05:50 PM
97hb's Avatar
Default Re: Which B16 is easiest to swap into 98 EX? (MikeMAN)
You got obd2, you should stick with obd2. Plus in most states its illegal to get a motor older than the car.
Old Jul 31, 2002 | 07:39 AM
MikeMAN's Avatar
Default Re: Which B16 is easiest to swap into 98 EX? (97hb)
if i swap an OBDII i won't loose my AC will I?
thanks,
mike
Old Jul 31, 2002 | 11:01 AM
Jackson's Avatar
thanks,
mike
Not if you get the right a/c bracket. The 99-00 si motor would be your best bet, but you will not be able to use that engine harness.
Old Jul 31, 2002 | 11:12 AM
Kamin's Avatar
Default Re: Which B16 is easiest to swap into 98 EX? (Jackson)
you can use your stock harness.
toyotaninja
May 15, 2011 11:30 AM
Muuugen
Sep 16, 2008 05:16 AM
Dave.ex
May 16, 2008 01:56 PM
hcivic99
Apr 11, 2006 06:18 AM
teameco
Nov 14, 2005 05:12 PM
