1997 ACURA INTEGRA LS SWAP, 84,xxx MILES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1997 Ls Swap, Everything is there except axels. The motor is a B18B1 which came out of a completely stock Integra. Milage on the motor is 84,xxx miles. The motor has no issues and has been well maintained and taken care of. Car has clean vins and is a legit motor. The following items had been changed on the car at approximately 72,xxx miles.
-Timing belt,water pump, valve adjustment done to factory specs,new valve cover gasket,and gromet set, transmission flush, and distributor o-ring was just recently changed out,along with spark plugs,wires,cap and rotor.
What will be included in the swap-
-Complete long block and transmission with ac bracket,ac compressor,power steering pump and bracket,alternator,intake manifold,distributor,sensors,o2 sensor, starter, wiring harness,etc. Basically how it came out of the car.
-All motor mounts and brackets out of the integra
-Ls integra shiftlinkage and shifter
-Stock ecu out of the integra
-Wiring harness
-transmission(went ahead and got the flywheel resurfaced,just installed a new honda oem throwout bearing, and a newer oem clutch that i had sitting around with 5,000 miles on it.)
All you are missing out of the swap are axels.
Asking price for the swap is 1500obo, considering all the work and parts that have been put into the motor.No trades, just cash.
No pms, i rarely come on honda-tech, just call me at 707-372-3102. Thanks
-Wiring harness
