trying to convert f22a6 motor to run with f22b2 distributor
Old Nov 8, 2008 | 11:15 AM
motorhead138's Avatar
Default trying to convert f22a6 motor to run with f22b2 distributor
ok so the f22a6 in my 92 accord blew up and i put in a f22b2 i got for $300 i put a new t-belt and all that crap. Now the problem is i can't get it to run. I got the f22b2 is from a newer car (94-97 i believe) so i went and got the ecm, wiring harness, distributor and coil. The main diffrence between the harnesses are-distributor plug-and crank sensor-. So at the moment I don't know if the new ecm will work without a crank sensor, so i am trying to find some info on wiring up the new style 4 wire dist plug to the old 8 wire harness. Any info would be great.
str8up720
10
Oct 9, 2018 07:14 PM
Madspliffa
Mar 15, 2014 05:24 AM
Madspliffa
Mar 13, 2014 04:28 AM
BrothaSit
Jan 5, 2011 06:19 PM
greddy2smoke
Jul 16, 2007 04:27 PM
