I have a very simple brake question for you guys
Old Nov 8, 2008 | 09:04 AM
Phat8186's Avatar
Default I have a very simple brake question for you guys
Ok I have a 1995 Civc EX coupe, which for some reason came with rear drums instead of disk werid if you ask me. Anyway I need to do my brakes and would really like to swap out the rear drums for rear disk. What applications will work with my 5th gen civic to make it s PnP process. Any insight would be awesome.
Thanks in advance
Alex
Old Nov 8, 2008 | 09:07 AM
turbojdmhatch's Avatar
Default Re: I have a very simple brake question for you guys (Phat8186)
the whole rear trailing arm....stuff like thats not really a "plug and play" process...i know fastbrakes makes a kit that you can take off the whole drum and then bolt on the disc but its a 11 inch disc and a lot of work
Old Nov 8, 2008 | 09:15 AM
Phat8186's Avatar
Didnt really mean plug in play bad choice of words really. I just wanted to know what will work, just dont want to buy something that will not even work with my year civic. I know that I will have change my whole trailer arm. Just want to know which civic or intergra trailer arm can I use.
Modified by Phat8186 at 2:01 PM 11/8/2008
Old Nov 8, 2008 | 09:21 AM
davefromPA's Avatar
Default Re: (Phat8186)
92-95 civic disks, trailing arms
94-01 teg disks, trailing arm
new e-brake cables for both though.
and if you do not upgrade your front disks, you can keep you brake booster, master cylinder and proportioniing valve.
Old Nov 8, 2008 | 09:23 AM
BryanM.'s Avatar
Resident Gearhead
94-01 Integra, EG Si and EX rear trailing arms will work.
Only EXs that came with with ABS had rear discs.
Old Nov 8, 2008 | 09:53 AM
boost and bass's Avatar
I did the whole rear trailing arm it was simple bolt on
Old Nov 8, 2008 | 10:03 AM
Phat8186's Avatar
Default Re: I have a very simple brake question for you guys (mcvtec)
But my civic is an EX, must mean that it doesnt have ABS then
Old Nov 8, 2008 | 10:08 AM
Phat8186's Avatar
So this item that I am looking at on ebay should work just fine correct
http://cgi.ebay.com/ebaymotors...ories
Old Nov 8, 2008 | 10:50 AM
JDMbut no different than usdm INTEGRA GSR 4 LUG CONVERSION CIVIC RAREwtf makes it rare? DISK BRAKE
god i hate ebay....you know somethings played out when every seller puts JDM on every item they are selling
Old Nov 8, 2008 | 10:54 AM
94EG8's Avatar
Seagull Management
ABS was optional on EX coupes in '94 and '95. It was not available at all on '93 coupes. It was standard on '92 - '95 EX sedans and optional on the '94 Si hatchback.
Old Nov 8, 2008 | 10:55 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (turbojdmhatch)
"JDM Integra GSR"
No such thing LOL
Edit: Integra Si VTEC and SiR-G
Modified by mcvtec at 3:13 PM 11/8/2008
Old Nov 8, 2008 | 10:58 AM
Default Re: (mcvtec)
Originally Posted by mcvtec
"JDM Integra GSR"
No such thing LOL
?confused want to know answer(not sarcastic just wondering)
Old Nov 8, 2008 | 11:04 AM
94EG8's Avatar
Seagull Management
Well technically no there isn't a JDM GS-R, its known in Japan as the SiR-G.
Old Nov 8, 2008 | 11:07 AM
Default Re: (94EG8)
wtf japan gets the good stuff but they are confusing as fkcu
Old Nov 8, 2008 | 11:12 AM
94EG8's Avatar
Seagull Management
Sorta, but actually theres a lot of cool stuff thats labled JDM that really isn't JDM, or it was available in a ton of other countries, just not the US. Those EG6 SiR steering wheels? we got those in canada on CX and DX hatchbacks and most sedans. Stanely clear corners? Europe got those as well, south america too I believe. and parts of Europe got way nicer headlights than either the US or Japan, they're glass like the USDM versions, but they don't have the nipples in the glass, they're also power adjust, the switch goes in the center console and allows you to adjust the beam up and down from inside the car.
Old Nov 8, 2008 | 11:15 AM
Default Re: (94EG8)
yea i know most of that stuff i just wasnt sure why there wasnt a GS-R
Old Nov 11, 2008 | 07:13 PM
Phat8186's Avatar
Thanks guys I bought the rear disk conversion for my CIVIC from the eGay link that I posted.
Old Nov 11, 2008 | 09:18 PM
slo_hatch's Avatar
for a rear disc brake swap...check out this thread.
https://honda-tech.com/zerothread?id=812062
asianflava
Dec 8, 2008 11:14 AM
LSej1
Oct 27, 2007 11:58 AM
solidinside
Jul 29, 2007 01:40 AM
ED3_FTW
Dec 16, 2006 04:32 PM
func-tion
13
Feb 9, 2004 10:24 PM
