Half Shaft Help Please
Old Nov 7, 2008 | 06:28 PM
Mill-Town's Avatar
Default Half Shaft Help Please
Edit: Engine b16
Trans: B16 w/Itr lsd finial
Is there a difference between 92-00 and 91-88 halfshafts?
I needed axels and a half shaft to finish my car, And my bud had some from his 91 b16 swap that he gave me. When I installed the pass axel it went in with out and problems But when I tried to install the half saft it wouldn't go in. As if the spine count is different or something?
Could some one shed some light on this for me please
Old Nov 9, 2008 | 08:56 AM
nikitad's Avatar
Default Re: Half Shaft Help Please (Mill-Town)
Is the tranny hydro or cable?
There is a difference between EF SIR shaft and LS shafts of the same years - i believe it's the shape/length.
90-93 and 94-01 LS shafts are the same shape/length wise, but 94-01 requires a bigger seal on the tranny. Splines should be all the same on any of them.
Old Nov 9, 2008 | 03:48 PM
tilegend's Avatar
90-93 driver side is not the same as 94-01
90-93 is female. and 94-01 is male.
Old Nov 9, 2008 | 04:35 PM
nikitad's Avatar
Default Re: (tilegend)
gsr is male, ls is still female
Old Nov 9, 2008 | 05:00 PM
tilegend's Avatar
Default Re: (nikitad)
wrong again....
94+ intermediate shaft LS AND GSR are the same... only difference is the seals
90-93 intermediate shaft and axle
or if you want to check hasport:
http://www.hasport.com/news/ar...2.htm
top is LS/GSR 94-01
middle is SIR
bottom is 90-93
Modified by tilegend at 9:10 PM 11/9/2008
Old Nov 10, 2008 | 02:17 AM
nikitad's Avatar
It's actually NOT clear from hasport's website (seen it before),
but i went and checked out part numbers
and both 94 up LS and GSR are 44500-SR3-J01, so you're right.
Thanks, i learned something new.
Mr C1vic
11
Jun 13, 2011 09:40 AM
Mill-Town
Nov 8, 2008 11:53 AM
ef 4 door
Feb 5, 2007 12:32 PM
fatboyslim44
Jan 9, 2006 07:10 PM
