Subject: FS: OBDII Greddy Intelligent Informeter - $290 Chicago
Old Nov 7, 2008 | 03:18 PM
half jdm's Avatar
Default FS: OBDII Greddy Intelligent Informeter - $290 Chicago
I have for sale a brand new Greddy Intelligent Infometer (Blcak color). This is a really neat tool that is completely plug and play, no splicing at all. Great for datalogging and is really easy to use. The Greddy Intelligent Informeter is a inexpensive solution to monitor your your veichles parameters via the factory OBDII Port. This will allow you to read up to 25 pieces of information.
Features:
-Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp.
-Along with being useful it is also stylish. The face plate can be changed to different colors to match your interior as well as the display background.
-For use with veichles which use OBD2 Ports, also can plug into a cigarette lighter plug that powers up the unit.
-Features a easy to read Color LCD Screen, Monitor Record and Playback, and 180 Degree Monitor Flexibility.
This unit will work with all Japanese OBDII vehicle manufactures listed:
Nissan(OBD1 and II), Toyota, Honda/Acura, Mitsubishi, Subaru, Daihatsu... You can test before you buy.
I opened it to test it on my car, but it will not read on my ECU. (My Nissan SR20DE) So If you are interested, email me and I promise we can hook it up before you buy to confirm it is compatible with your vehicle. Hooking it up to test takes literally a minute, its just like testing for OBDII CEL codes via the same port under your dash.
I am looking for $290 or trade for... I paid over $350 shipped for this so i am taking a loss because it doesn't work on my car. Email me or PM jpcallmotorATyahooDOTcom if you want to check it out, I am located on the southside by 87th Kedzie and it would be no problem to meet up.
Old Nov 9, 2008 | 09:39 PM
Chester Rumble's Avatar
Default Re: FS: OBDII Greddy Intelligent Informeter - $290 Chicago (half jdm)
I noticed it will work for OBD1 Toyotas. Will it also work with an OBD1 Honda (plug and play)? No splicing...
Old Nov 11, 2008 | 01:58 PM
half jdm's Avatar
^^^ According to the unit it works with OBDI Nissan, but I am not sure about Honda. I will test it out on my 94 Accord or see if I can find some more info on it for you.
Also, you are more than welcome to come and test it out. Thanks for the interest.
Old Dec 21, 2008 | 11:28 AM
half jdm's Avatar
Default Re: Subject: FS: OBDII Greddy Intelligent Informeter - $290 Chicago
Bump.
Old Dec 21, 2008 | 02:25 PM
freddysEF's Avatar
PM sent
Old Jan 24, 2009 | 01:49 PM
half jdm's Avatar
Bump - $250!!!
Old Jan 26, 2009 | 02:18 PM
half jdm's Avatar
Up this shizt!
Old Jan 27, 2009 | 07:32 PM
half jdm's Avatar
jfhdkjfhds
Old Jan 29, 2009 | 02:14 PM
half jdm's Avatar
bump 1...
Old Jan 30, 2009 | 02:27 PM
half jdm's Avatar
Happy Friday bump...
JJ-Built
Aug 27, 2007 07:59 PM
sndc5
Mar 15, 2007 06:18 PM
sndc5
Feb 5, 2007 01:54 PM
TimeRacer
Jul 28, 2006 11:38 AM
