Chipped PR3 to run D16Z6 or D15B Vtec in EF?
Old Nov 7, 2008 | 10:59 AM
94EG8's Avatar
Seagull Management
Default Chipped PR3 to run D16Z6 or D15B Vtec in EF?
Has anyone run a chipped PR3 in an EF to run SOHC Vtec? All i've heard about running SOHC vtecs in EFs were you needed to convert the whole thing to OBD1 due to there not being an OBD0 ECU. But is there any reason you couldn't chip an OBD0 ECU to run it, or am I missing something really obvious here? Not looking to do, I just want to know if its doable.
Old Nov 9, 2008 | 07:45 PM
LA_HONDAS's Avatar
Default Re: Chipped PR3 to run D16Z6 or D15B Vtec in EF? (94EG8)
just run as is
it'll just run a lil rich
Old Nov 9, 2008 | 08:04 PM
94EG8's Avatar
Seagull Management
Default Re: Chipped PR3 to run D16Z6 or D15B Vtec in EF? (LA_HONDAS)
Originally Posted by LA_HONDAS
just run as is
Well I knew I could do that, that wasn't the point of the question. It seems like a really simple solution, yet i've never seen anyone do it.
Old Nov 9, 2008 | 08:22 PM
LA_HONDAS's Avatar
its doable but at the end of the day obd1 is better
Old Nov 11, 2008 | 10:04 AM
Relic1's Avatar
A chipped/tuned PR3 will run a SOHC fine. (I've seen it myself)
Only advantage to converting to OBD1.... more options.
Old Nov 24, 2008 | 04:20 PM
jjs89crxsi's Avatar
Seemed rather simple to me too... However, being a noob, and never having tried to program my ecu (yet) I've herd that the obd1 distributor produces a different signal than the obd0?
When I chip it and use the d16z6 maps will this be an obvious change or is it something more intricate?
Guess I should get me an eeprom burner and tinker with it before I ask too many questions, I just want to have my head around what I'm looking at before I get into it...
Old Nov 25, 2008 | 04:46 AM
jjs89crxsi's Avatar
I've just been reminded to me that there is an OBD1 version of the PR3....
You're post has been my my only real proof that this IS possible. You say you've seen it, is it possible it was the OBD1 version?
I hope it was 0... I don't want to find an OBD1 PR3 or a P28...
Old Nov 25, 2008 | 06:35 AM
LA_HONDAS's Avatar
pr3 is obd0 not obd1
and you can get p28s on ebay all day long
Old Nov 25, 2008 | 08:54 AM
94EG8's Avatar
Seagull Management
There were OBD1 PR3s as well, they came in '92 - '93 JDM integra Rsi's and Xsi's, just not as common and not often talked about. In my OP I was refering to the OBD0 PR3. The whole point of my original post was that I wanted to see if it was possible to run a D16Z6, or any OBD1 SOHC Vtec for that matter, properly without converting to OBD1. D-series swaps in EFs are simple and cheap, until you get the wiring portion of the swap, I know PR3s are somewhat hard to find, and will probably cost more than a P28, but I figure the ease of installation will offset that somewhat. This was really more than anything a "can this be done?" type question.
Old Nov 25, 2008 | 09:09 AM
kicked25th's Avatar
Yea you could use a pr3. Though I think in your case I would go LS swap instead, and i LOVE the D.
Old Apr 6, 2009 | 09:34 PM
SingleCamin's Avatar
YESH U CAN IM RUNNINING THE pr3 ON MY d15b just plug and play and connect the vtec wires
jztoy
Jul 4, 2009 09:02 PM
srt4pilot
May 10, 2009 05:10 PM
Suck my DX
13
Dec 6, 2006 05:43 PM
haggar
Mar 20, 2006 05:05 AM
Si2See
13
May 19, 2005 11:13 PM
