Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 Civic Si wont start
Old Nov 7, 2008 | 09:00 AM
nerol86's Avatar
Default 2006 Civic Si wont start
I'm posting this for a buddy of mine, and I hope someone can help me out. My friend has a 2006 Civic Si. Last night he went to start it and it wouldn't even turn over. What's strange is that when the key is in the II position, all the dash lights came on and started flickering when you would hit the brakes or the clutch pedal. When he would try to start it, it would make a grinding noise. Sounded electrical. Only mods done to the car is a SRI, and some guages on the door pillar. Any ideas what could be causing this?
Modified by nerol86 at 10:09 AM 11/7/2008
Old Nov 7, 2008 | 09:33 AM
SIVIC 3's Avatar
check the battery. i think its the battery.
Old Nov 7, 2008 | 09:47 AM
draken187's Avatar
Default Re: (SIVIC 3)
electrical grinding? his dash lights are nice and bright? do his headlights work? if they do its the starter... sounds stuck might get lucky and be able to bang on it with a broomstick and get it loose... my winter vehicle is a 99 accord and i have to bang the starter once in a while.... since it sits most of the summer
Old Nov 7, 2008 | 10:25 AM
JTaudio0212's Avatar
Default Re: (draken187)
Starter.. or when you were wiring the gauges somehow the clutch switch got loose/unplugged and it will not activate the starter unless the clutch is activated.
also... is the security light flashing on the dash after you try and start it? Could be a factory anti-theft module not allowing the vehicle to activate the starter.
Check the negative battery terminal, make sure there's no corrosion and make sure its tight.
good luck
Old Nov 7, 2008 | 12:16 PM
civicguru's Avatar
Default Re: (JTaudio0212)
Definately the starter, how many miles on the car???? Cause the battery is supplying the juice to crank the starter but the starter is not engaging??? DO teh broom stick trick if it is stuck it will come loose or else just swap the starter with a new one....should be straight forward task...and also should be considerably cheap as well...
later...
JFK
Old Nov 7, 2008 | 12:51 PM
byronl's Avatar
Default Re: 2006 Civic Si wont start (nerol86)
sounds like a grounding issue
Old Nov 7, 2008 | 02:53 PM
yuning83's Avatar
Default Re: 2006 Civic Si wont start (byronl)
I think it's the battery, but something else I had problem with was if your SRI filter is loose, car will shutdown. And if the sensor on that arm has control over start and stop then it might be bad also.
If it's the battery you can usually tell because the dash will light up and when you crank, the dash light will flicker and goes off.
Old Nov 9, 2008 | 06:24 AM
nerol86's Avatar
Default Re: 2006 Civic Si wont start (yuning83)
Well, it turns out it was the battery. Thanks for the replies.
Old Nov 9, 2008 | 09:10 AM
SIVIC 3's Avatar
sivic3 ftw!
Old Nov 9, 2008 | 03:21 PM
Originally Posted by SIVIC 3
sivic3 ftw!
NICE WORK!
Old Nov 10, 2008 | 01:03 PM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Its the battery, I had that problem at the drive in.
Old Nov 10, 2008 | 01:15 PM
teg_95's Avatar
Default Re: (100miles+)
a buddy of mine had the same problem, changed to alternator. and started right up.
Old Jan 5, 2021 | 10:33 AM
Jenna Rusk's Avatar
Please help! I've got a similar problem. 2006 Civic si would not crank or start. Changed starter to no avail. Checked the battery but it seems fine. We've checked a few grounds but not all of them yet as some are hidden. It just wouldn't crank one day. All dash lights come on but nothing. After messing with it a couple weeks it now makes a crazy clicking noise from the fuse box under the hood but after a few tries will finally just turn over and start. Could it be ignition related? TIA!
Old Feb 15, 2021 | 03:44 PM
Chaunceworthy's Avatar
Please let me know what, if anything, you find out as I am dealing with the same problem. I've replaced the battery and starter as well. Sometimes it simply won't start.
Thanks 😁
Old Feb 15, 2021 | 08:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Thanks 😁
Inspect your charge harness... this is a common problem with 2002+ "K" series platforms. Look for unusual corrosion, frayed wire, dark stranding, etc. If you find any of these, replace the charge harness.
Gwells
Oct 30, 2017 04:12 PM
Grym
Aug 24, 2013 06:42 PM
Civic_EF9_89
Nov 29, 2009 11:08 AM
Predatorinc
Jul 13, 2007 03:59 PM
Leimokei
Jan 8, 2004 11:40 AM
