camber
Old Jul 30, 2002 | 03:38 PM
seineil's Avatar
Default camber
i need to fix my camber any ideas on how i got front camber kit but its still eating the inside of the tires the back um just going to use washers i dont wantt o keep spending money on new tires
[Modified by seineil, 12:39 AM 7/31/2002]
Old Jul 30, 2002 | 05:49 PM
M-EJ1's Avatar
Default Re: camber (seineil)
You say you do have a front camber kit, but your tires are still wearing funny? Did you get an alignment after you lowered your car? Sounds like toe to me... the inner edges of my old Yokahomas wore completely bald when I lowered my car... not from camber (only a 1.5" drop), but from incorrect toe.
Old Jul 30, 2002 | 06:38 PM
tonyxcom's Avatar
Default Re: camber (matt-eg)
Ive got 12k miles on my tires now, My Front camber is SET to -1.75 and my rears are SET to -1.5 and I show very very little "camber" wear, but my toe is a ZERO front and back.
Moral of the story, you dont need camber kits, you need a good alignment where the guy actually does his job and zeros your toe.
Old Jul 30, 2002 | 07:06 PM
EKB18BPR3's Avatar
Default Re: camber (tonyxcom)
i think anytime u get ur car lowered..4 inch or 1 inch u need cambers...
Old Jul 30, 2002 | 07:29 PM
tonyxcom's Avatar
Default Re: camber (dniedacess)
ENTIRELY NOT TRUE.
Old Jul 30, 2002 | 11:09 PM
nijia555's Avatar
so can some1 tell me for real do i need a camber kit for a 1.5 to 2 at the max drop. oh also the front, back, or both. its confusing some say yes some say no. I am trying to make up my mind if i should do this or not, i am trying to get the cost together
Old Jul 30, 2002 | 11:19 PM
tonyxcom's Avatar
Default Re: camber (nijia555)
NO YOU DO NOT NEED THEM.
When you lower your car, you WILL have camber.
I have said this a thousand times....CAMBER DOES NOT WEAR OUT TIRES....BUT TOE DOES!!!!!!!!!!!!!!!!!!!!!!!
So after you lower your car, take it to a good alignment shop and make sure they set your front and rear toe to ZERO. And you will be fine.
[Modified by tonyxcom, 8:20 AM 7/31/2002]
Old Jul 30, 2002 | 11:26 PM
Vanilla4215's Avatar
Tonyxcom is totally right. for Tony.
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
climb_on
Jul 1, 2007 01:04 PM
E36 Guy
16
Apr 7, 2006 09:58 AM
vdub08
Suspension & Brakes
19
Sep 3, 2005 01:14 PM
todds94teg
Sep 5, 2003 06:14 AM
