can you chip a obd1 prelude ecu? p13
Old Jul 30, 2002 | 03:30 PM
turboex's Avatar
Default can you chip a obd1 prelude ecu? p13
if i buy a ebay chip can you use this in a prelude ecu? the ecu is a p13. thanks
Old Jul 30, 2002 | 03:40 PM
satan_srv's Avatar
Default Re: can you chip a obd1 prelude ecu? p13 (turboex)
JDM chips don't work on USDM ECUs...and vice versa. Somebody correct me if I'm wrong. P13's are relatively unchippable...
Old Jul 30, 2002 | 04:21 PM
aklucsarits's Avatar
New User
Default Re: can you chip a obd1 prelude ecu? p13 (satan_srv)
That's correct based on what I've been told too. For some reason, JDM P13 programs only work on JDM P13 ECUs and US P13 programs only work on US P13 ECUs.
The US P13 can be chipped. There are several good programs out for the US P13. I used to have a Dinan-chipped P13 that I just recently sold. That ECU was a great improvement in my otherwise-stock 1993 Prelude VTEC that I used to own.
Andrew
[Modified by aklucsarits, 8:35 PM 7/30/2002]
Old Jul 30, 2002 | 04:44 PM
turboex's Avatar
Default Re: can you chip a obd1 prelude ecu? p13 (aklucsarits)
i have done a hondata install with the chip and all, but what do i have to do with the p13 to put a chip in it?
Old Jul 30, 2002 | 05:21 PM
satan_srv's Avatar
Hondata can only do Stage 1 on a P13...so that's fuel and ignition timing, rev limits but that's it...no boost...no speed limiter (JDM). I guess the same as Dinan...
Somehow they can't get to Stage 2 levels or use the interface box...weird.
Old Jul 30, 2002 | 08:00 PM
prospeed's Avatar
I Reprogram ecus for both the jdm and usdm p13's. They are chippable.
Old Jul 30, 2002 | 08:15 PM
satan_srv's Avatar
Default Re: can you chip a obd1 prelude ecu? p13 (prospeed)
Well suck me sideways!! Isn't that nice...I wish I had know before I bought a P72!!!
Old Jul 30, 2002 | 08:16 PM
satan_srv's Avatar
Why can't Hondata do it?
Old Jul 30, 2002 | 10:58 PM
prospeed's Avatar
sorry bout that! well the p72 isnt too bad. The reason why is the format is different on the p13 ecus they run a different board. The other b-series ecus are compatible with hondata because they are all on a similar platform. Hope that helps!
Old Jul 31, 2002 | 03:59 AM
turboex's Avatar
when install this chip do all you have to do is put in the socket and the chip? or what? thanks
Old Jul 31, 2002 | 06:36 AM
DirtyLude's Avatar
You must be confused here, Joel. You already knew the P13 was chippable. Yoshio will custom tune P13 chips if you want. Hondata still doesn't offer stage2 P13 systems, because it's not worth it to them.
Old Jul 31, 2002 | 07:45 AM
satan_srv's Avatar
Default Re: can you chip a obd1 prelude ecu? p13 (DirtyLude)
Oh yeah, the techtom stuff....right!
SOblOwN
Sep 20, 2012 12:45 AM
ironcheftony
Engine Management and Tuning
Aug 12, 2012 08:12 PM
Postulio4jOO
Jul 30, 2009 10:08 AM
Prelude MIke
Jun 15, 2004 05:21 PM
