k20a2 into EP3 swap questions, swap done, wont start
Old Nov 6, 2008 | 09:26 PM
dcletten's Avatar
Default k20a2 into EP3 swap questions, swap done, wont start
ok, heres the deal, my buddies doin the swap, everythings done. but the car wont start.
k20a2 engine
k20a3 trans
k20a2 ecu
k20a2 engine harness
k20a3 chaging harness
k20a3 knock sensor
sounds like the injectors arent firing. i tried finding a writeup to see if theres anything electrical has to be done. but no such luck finding anything
the only thing i found is that the k20a2 knock sensor has to be rewired, but thats all i found. the stock k20a2 knock sensor was broken when he got the engine, so he swapped the one from the a3(wondering if thats my issue, or the pinout is different on the charging harness)
also when you go to start the car, the check light flashes 5 times then shuts off(my buddy has my scanner, and i cant get a hold of it). any help would be GREATLY appreciated, thanks in advance
Dan
Old Nov 6, 2008 | 10:00 PM
dcletten's Avatar
i think i may have figured it out, something about reprogramming the immobilizer, again, any input would be appreciated
Old Nov 6, 2008 | 11:58 PM
tunerkid7's Avatar
Default Re: (dcletten)
wrong section man
Old Nov 7, 2008 | 12:31 AM
20CiviC02Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcletten &raquo;</TD></TR><TR><TD CLASS="quote">i think i may have figured it out, something about reprogramming the immobilizer, again, any input would be appreciated</TD></TR></TABLE>Yeah the immobilizer is what the problem is, that or a ground wire that isn't connected. More than likely the immobilizer because of the K20a2 ECU.
Old Nov 7, 2008 | 12:39 PM
SkoundrelUSA's Avatar
cute little bastard
Try plugging in your PNF or w/e the EP3 ECU is just to see if it starts?
Old Nov 7, 2008 | 07:02 PM
dcletten's Avatar
tried that, still didnt start, didnt know if it even would though with that ecu
Old Nov 7, 2008 | 09:57 PM
burnout8488's Avatar
Don't bother with the A2 ECU right now. Get the car to start on the A3 ECU, then figure out the immobilizer issue with the A2 ECU.
If it won't start on the A3, you'll never know if its the immobilizer or another problem if you try using the A2.
Old Nov 7, 2008 | 11:57 PM
rsxtj's Avatar
Banned
Default Re: (burnout8488)
that is true, you must use the ecu of your own car, that would otherwise have to reprogram your key with the new ECU, for that reason the car did not turn on
Old Nov 8, 2008 | 05:09 AM
WhiteOnRice's Avatar
Default Re: (SkoundrelUSA)
No. There's another problem. The a2 can be ran on the a3 ecu. Just don't rev high before you get the car to Acura to reprogram.
This swap is as straight-forward as it gets. Check the part numbers on the a3/a2 knock sensors. If they are different, get an a2 KS. If they are the same, recheck your wiring.
Old Nov 8, 2008 | 07:21 AM
dcletten's Avatar
ok, yea the two knock sensors are different, i just wasnt 100% sure if that would keep the car from starting or just throw a check light for knock sensor, BUT, if that is the case, wouldnt it still start with the a3 ecu using an a3 knock sensor? the a2 harness was untouched from the time we got the engine, the only thing thats re-used from the a3 was the trans, knock sensor, and the a3 charging harness, and i think maybe the a3 alternator. again i didnt do the swap, he just called me for troubleshooting
Old Nov 8, 2008 | 11:38 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Do you have any RSX Buddies with an 02-04 rsx running k-pro? Ask them if you can use their ECU just to start and test your car. It will bypass the immobilizer and then you can check on the knock sensor from there.
Old Nov 8, 2008 | 07:47 PM
dcletten's Avatar
ok, from what he told me today, he swapped back to the a3 ecu, and now the injectors are clicking but it still wont start. theres no differences between the a3 charging harness is there?
Old Nov 8, 2008 | 09:18 PM
JCL's Avatar
JCL
dont mind me but, does the car have gas. yes its a dumb question but alot of people over look that.
Old Nov 10, 2008 | 07:47 PM
dcletten's Avatar
fixed, he threw the a3 ecu back in, started getting fuel, but still wouldnt start, swapped coil n new plugs n started right up, thanks for everyones help
Old Apr 4, 2012 | 10:50 PM
jdmdomo's Avatar
Default Re: k20a2 into EP3 swap questions, swap done, wont start
Cool .
Old Apr 5, 2012 | 08:04 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Originally Posted by jdmdomo
Cool .
why the hell did you bump 4 year old thread
Crxh22ajdm
Dec 21, 2012 01:55 AM
amnbassist
Dec 2, 2011 09:24 AM
oneEg1Tc
15
May 10, 2009 08:58 PM
dcletten
Nov 7, 2008 09:50 AM
ram0869
Jul 23, 2008 02:10 PM
