right rear door stuck
Old Nov 6, 2008 | 08:19 PM
dylokjai's Avatar
Default right rear door stuck
My right rear door on my 98 4dr accord no power doors is stuck i cant open it from the inside handle or outside handle..please help asap
Old Nov 7, 2008 | 04:00 AM
P_Adams's Avatar
Default Re: right rear door stuck (dylokjai)
Sounds like someone tryed to get into your car without your knowledge.
The most direct route will (most likely) be to take the interior trim panel off to gain access to the lock release mechanism. This is going to require some finess since the door panel is often shadowed by surrounding trim when the door's closed.
If you've a Honda Service Manual or are familiar with the location of all the fasteners are, you MIGHT be able to get it off.
I'd suggest finding yourself an independant garage which specialize in Honda's, grit your teeth and let them do it.
P
dhealy3154
Honda CR-V & Element
Jan 16, 2019 04:41 PM
hondaX2
Paint and Body
Apr 13, 2014 02:04 PM
ssssmashing
Jun 25, 2010 10:22 AM
thomas998
Feb 2, 2010 07:45 AM
