obd1 to obd2
Old Jul 30, 2002 | 03:10 PM
PhuckinHondas's Avatar
Default obd1 to obd2
does anyone make a harness for the ecu to convert from obd 1 to 2
im gettin my c5 swap but i want to use the type r ecu instead of chippin mine
Old Jul 30, 2002 | 03:25 PM
allmtr's Avatar
Default Re: obd1 to obd2 (In The 16s)
i think all you have to do is change the distributor and injectors to type-r.
Old Jul 30, 2002 | 03:26 PM
W.Zero's Avatar
youll lose power. the swap wont be the same if its not obd1. your better off selling the ecu and getting an obd1 chipped.
Old Jul 30, 2002 | 03:27 PM
W.Zero's Avatar
Default Re: obd1 to obd2 (W.ZeroB18C1T)
where you located my homie might buy it for his 00 si.
Old Jul 30, 2002 | 05:43 PM
acuracing's Avatar
You'd have to get someone to make the harness for you. No one sells them. Skunk2 makes OBDII-OBDI adapters. But no one makes OBDI-OBDII harnesses. I'm going the same route. I would only recommend it if you are going to do it for emissions purposes...
Old Jul 30, 2002 | 06:19 PM
shermanyang's Avatar
Default Re: obd1 to obd2 (acuracing)
that's gonna be a pain in the **** because you're car doesn't have all the ODBII plugs. unless you're gonna switch out your whole wiring harness i'd advise you to just chip your ecu!!
Old Jul 30, 2002 | 08:06 PM
prospeed's Avatar
I offer them for obd-1 to obd-2. Check out my site under the harness adaptors!
95 iteg
10
Jun 3, 2013 11:36 AM
nothing_shocking
Engine Management and Tuning
Dec 1, 2010 04:00 PM
NsX_CrX
Nov 19, 2005 12:49 PM
Type RS
Nov 18, 2002 10:09 PM
