spoon monoblocks on integra ls?
Old Nov 6, 2008 | 01:15 PM
danthemang3's Avatar
Default spoon monoblocks on integra ls?
well it seems as if my only options to run a big brake kit on my 94' ls and keep 16" wheels is either. the endless set up for $2600, spoon twin block with itr caliper and i beleive fastbrakes make a bracket. or if there is a simple way to make the spoon monoblocks to fit. thanks
Old Nov 7, 2008 | 01:58 AM
nautica_t's Avatar
pm username FabFive
he has done it on his GSR.
i believe you need itr sliders that has been modified shims and you'll need vtec prelude rotors redrilled to 4x100
Old Nov 7, 2008 | 07:20 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: spoon monoblocks on integra ls? (danthemang3)
You will need a custom rotor for the Spoon calipers. 92-96 Prelude VTEC rotors redrilled to 4x100mm are 2mm too tall for that caliper.
Old Nov 7, 2008 | 08:30 AM
SuzukaBlueAP2's Avatar
Default Re: spoon monoblocks on integra ls? (Dogginator)
doesn't Rotora make a kit that clears 16" wheels?
Old Nov 7, 2008 | 12:59 PM
Default Re: spoon monoblocks on integra ls? (SuzukaBlueAP2)
only for the type-r's that i have seen and i guess it's not a big deal but their calipers aren't forged. although i don't know if the spoons are forged or not.
Old Nov 7, 2008 | 08:38 PM
94VTEC2TONE's Avatar
look at a forum on here. they redrill the itr rotors i believe to 4x100 or somthing and they come to ur door like that. ask brakeparts specialist on here
Old Nov 7, 2008 | 10:21 PM
not so JDM Dan's Avatar
Default Re: (94VTEC2TONE)
calipers bolt right on, 92-96 prelude re-drilled rotors with 1/8th inch spacer behind the rotor, works perfect on my dc4
Drew17th
Suspension & Brakes
13
Aug 30, 2009 07:13 AM
00gs-r
Mar 20, 2007 06:36 AM
luckypon7
Feb 3, 2004 09:10 AM
bhcvc
Sep 28, 2001 01:49 PM
