Honda s2k total rebuild
I need to to get a new rearend and tranny if anyone knows need to with stand 500 to 600hp
Putting costome roll bar, shine hard top, Block has been sleeved, low compression piston, new rods, same crank, same cams, head work, Prorace turbo kit stage 3, fab intake manifold, stef"s oil pan 4 stage drysump.
I have a complete Ford 8.8" differential set up and it's all togheter with the rear subframe and axles ready to sawp for your stock set up ( I will need ur stock subframe as an exchange)
This set up is good for 1000hp or a good 8sec pass
88, diff, differential, engine, ford, honda, kit, motor, rebuild, rebuilding, s2000, s2k, total, transmission
