how do you delete the abs unit from a 90 integra GS?
My abs unit is goin bad and it cost way to much to replace it. Someone suggested to just take it out of the car. I heard you have to get a 40/40 proportion valve and RS front brake line. I'm not sure if that's correct since I have never heard of this. But I have searched and search and still haven't found anything. So if anyone can help or have a link to somewhere someone has done this will be appreciated. Thanks.
what you need is
40/40 valve
brake lines that go from M/C to 40/40 valve (2x)
brake lines from 40/40 valve to front wheels (2x)
extensions from the rear lines to the 40/40 valve
and if you choose to stick with the 1" MC that you have now you'll need a M12x1 (male) to M10x1 (female) adapter (inverted flare)
if you get the NON-ABS booster i believe you must use the MC and booster together.
40/40 valve
Da1spaz247
Dec 11, 2007 06:28 PM
