problems with power fc ign timing need HELLLLLLLLLLLLLLLP!!!!!!!!!
Old Nov 6, 2008 | 05:54 AM
eddie5141981's Avatar
Default problems with power fc ign timing need HELLLLLLLLLLLLLLLP!!!!!!!!!
hello folks
my problem is that im trying to set up my ign timing on my engine and i wont work.
example: i put on the timing light and set my ign to 10deg, but when turn on my datalogic and check the ign is set to 16 deg. WHY?????
eny help
Old Nov 6, 2008 | 11:00 AM
inspector01's Avatar
Why would you set your dizzy to 10*?? Set it to 16* like it is supposed to be. And the datalogging is only telling you where it is firing, based on the distributor being set to OEM specs, so if you manually adjust your timing, the EMS doesn't know the difference, it only knows when the ECU says it is firing based of OEM specs.
raverx3m
Apr 9, 2012 09:15 AM
MonkeyBoy7805
11
Dec 2, 2010 11:38 AM
FlewByU352
Nov 13, 2010 07:27 PM
handa
Oct 24, 2004 08:27 AM
wizzards581
Feb 27, 2002 09:14 PM
