Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Valves adjusted - 1999 CR-V - Still no help
Old Nov 6, 2008 | 02:50 AM
alldrew's Avatar
Default Valves adjusted - 1999 CR-V - Still no help
Our 1999 CR-V has the following symptoms: runs rough (like pulling a trailer or driving on a washboard), check engine light comes on and stays on, when put on the diagnostic computer "misfire codes" are found. We have had the cylinder head replaced (along with all the parts associated), new plugs/plug wires/etc. and new electronic distributor by a local garage. When the problem continued we took it to our local Honda dealer who adjusted the valves and timing. The problem continues.
Thanks for the response about checking the valve adjustment - which has been done. Any further ideas. Has been a great vehicle and we want to continue enjoying it.
Alldrew
Modified by Dogginator at 9:47 AM 11/6/2008
Old Nov 6, 2008 | 05:02 AM
Ross 2.0's Avatar
In a Junkyard near you.
You don't have to start a new thread every time. Just reply to the old one. You might want to stop putting scams in your threads too before you get banned.
If the timing is correct, valve clearance is correct, compression is good. I would then look to see if the fuel injectors are spraying.
Old Nov 8, 2008 | 07:14 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Ross 2.0)
X2 for checking cam timing. A lot of people have trouble lining up cams on the B series timing belt R&R for some reason
Try throwing some pinch off pliers on the fuel return line and see if problems go away...if so, new injectors.
Old Nov 9, 2008 | 08:08 PM
dtapia's Avatar
Default Re: (Evs-One)
if the check engine light is on what is the dtc's ?
that info will help out.
chsmurphy
Honda CR-V & Element
35
Dec 20, 2021 12:25 PM
gummybear
Mar 23, 2008 12:08 PM
blum116
Aug 8, 2007 09:26 PM
Layziejoe775
Aug 26, 2006 03:54 PM
crix351c
10
Feb 25, 2006 06:28 PM
