Integra Walbro Pump Install
Old Nov 5, 2008 | 07:23 PM
Jayman_Gsr's Avatar
Default Integra Walbro Pump Install
Well I got the Fuel Pump in the mail and had it in the car within 30 min :D, Here is a lil write up on what I did:
Acura Intega Fuel Pump Install
Walbro
1. Remove the back seat, remove the cover using a philips head screwdriver. Then remove the 6 (10MM) bolts supporting the pump inside the gas tank. Also disconnect the fuel lines and electrical connections to pull the Pump out at a 45 degree angle.
2. Remove the pump from the brace by unpluging the connection then removing the clamps, lifting up on the pump to get the bottom lose the pull outward.
Stock Pump vs Walbro Pump
3.Install the new pump using the new fuel hose cut a bit shorter due to the larger size of the walbro. Use stock as a comparison to get a general idea. Connect the electrical connection reusing the plastic connection lock.
(Note. I had to reuse the screen)
4. Reinstall by CAREFULLY sliding the new pump in at that same angle, tighten the 10MM bolts then reconnect the fuel hoses and electrical connections. I tested before I tightend just to make sure. Then just screw the cover back on and install the back seat.
All DONE!
Not responsible for any damage you may do to your vehicle!!!
Old Nov 5, 2008 | 07:30 PM
92DAIntegraXSI's Avatar
good wrtie up just forgot to mention to disconnect the battery. not to many people are bright enoguh to figure that out. im sure you did thow.
Old Nov 5, 2008 | 09:32 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (92DAIntegraXSI)
Great write up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92DAIntegraXSI &raquo;</TD></TR><TR><TD CLASS="quote">good wrtie up just forgot to mention to disconnect the battery. not to many people are bright enoguh to figure that out. im sure you did thow.</TD></TR></TABLE>
What'll happen?
Old Nov 6, 2008 | 01:14 AM
FULLYBUILT2.0's Avatar
Default Re: Integra Walbro Pump Install (Jayman_Gsr)
nice
Old Nov 6, 2008 | 07:33 AM
Schister66's Avatar
Man U FTW
**added to the Forced Induction FAQ**
Old Nov 6, 2008 | 11:28 AM
Jimmy's Avatar
Global Moderator
Default Re: (Schister66)
Good idea.. added this to the integra forum faq
Old Nov 6, 2008 | 11:32 AM
twentyhurtz's Avatar
Default Re: (Jimmy)
* i like the, not responsible for any damage to your vehicle note! ha good stuff, i wish all honda's were like this, my girls 89 hatch has the gas level sensor there and her fuel pump is towards the back of the tank, thus you have to drop the tank to change the pump.
Old Nov 6, 2008 | 12:12 PM
mac_24_seven's Avatar
Default Re: (twentyhurtz)
Nooo!!! I got Walbro pump in the mail today and was gonna do a DIY. You beat me to it.
And I want to have a DIY in the Integra FAQ!! Guess I never did one good enough And 24 posts too. Gahh!!!
Enough with my whining, good job!
Old Nov 6, 2008 | 12:14 PM
Jimmy's Avatar
Global Moderator
Default Re: (mac_24_seven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">Nooo!!! I got Walbro pump in the mail today and was gonna do a DIY. You beat me to it.
Enough with my whining, good job!</TD></TR></TABLE>
Any helpful thread/info is added to the FAQ.. If you find something or make something post it in the faq thread and it will be added (as long as the images work)
Old Nov 6, 2008 | 12:17 PM
Default Re: (Jimmy)
YAY!!! I have 2 in the FAQ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
I'm pathetic, I know. That kinda made my day Tells you what kinda day I've had doesn't it?
Old Nov 6, 2008 | 01:56 PM
Jayman_Gsr's Avatar
Actually I didn't disconnect the battery but I did disconnect the main before working on it. My alarm doesn't like the battery to be disconnected.
Old Jan 28, 2010 | 02:09 PM
jonathan92591's Avatar
Thank you so much dude.
-JT
Old Mar 24, 2010 | 02:09 PM
acmoc's Avatar
Id this harder to do on the crx
I removed the cover and its cacked with mud
Old Jan 14, 2011 | 05:17 PM
bob102386's Avatar
great write up
Old Oct 18, 2012 | 10:10 AM
hondabantondb1's Avatar
nice nice
Old Nov 3, 2012 | 11:20 PM
stallion1515's Avatar
Not a very detailed writeup, but enough to get the gist of what to do if this is the first time you are doing it (like me this evening). Once you get the rear seat out of the way, it literally takes a minute to remove the fuel pump covers to access the fuel pump assembly. Removing the oem fuel pump out of the assembly is what takes the longest. You need to disconnect the electrical connection from the assembly to the oem pump (be careful here), wiggle the gasket out at the bottom of the pump and pry off the circular little metal holder on the bottom that keeps the strainer fixed to the pump. You also have to get the short hose off and all this w/o damaging the assembly. Then to install you just do what you did in reverse. It's easy in theory (like many things on automobiles but different once it's hands on...there's usually some kind of damn unexpected extra problem solving). It took me about an hour. I had to reuse the strainer b/c the kit I bought had a strainer that did not fit properly. I just installed an airtex aftermarket oem replica. Nothing special. It works fine though.
Old Aug 4, 2013 | 07:29 AM
lassoguy's Avatar
Very helpful. Thank you.
Old Aug 8, 2013 | 05:26 PM
dc2LS's Avatar
Nice write up.
IBriaIN
Sep 26, 2007 02:22 AM
shawn_crx
Mar 6, 2005 12:14 PM
sneakypete
Dec 27, 2004 10:12 PM
cvc323
Oct 31, 2003 08:02 PM
Andrew 825SM
Nov 27, 2002 12:18 PM
