LS tranny
so im looking to buy an LS cable tranny for my DA-T. They guy said all the foward gears work but reverse doesn't. He said something about the pin needs to be in there perfect or something.
Anyone knows what he's talking about?
I would first like to say to shoot for a GSR or type-r tranny if possible. The pin he's referring to is the dowel pin that holds the shift linkage to the shift rod on the transmission. If it's not tapped in flush enough to fit the clip over it, it's not in perfectly. Whoever would install a tranny like that is just lazy. Ask him if it goes into 5th gear...if it does, most likely it will go into reverse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonmaro »</TD></TR><TR><TD CLASS="quote">so im looking to buy an LS cable tranny for my DA-T.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">I would first like to say to shoot for a GSR or type-r tranny if possible. </TD></TR></TABLE>
He could but why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumada9 »</TD></TR><TR><TD CLASS="quote">well if you're running turbo ls tranny will work good with the long gear ratios. </TD></TR></TABLE>
He could but why?
I understand the gear ratio difference. Whether you are turbo or not, the GSR and Type-R trannys have shorter gears which means faster acceleration in any given engine setup. Unless you can't, or don't want to, shift faster, get the GSR for "bang for your buck."
Dont spread false info, you are just making more people stupid. A itr or gsr tranny will out perform a ls tranny any day of the week, even on a turbo motor.
I would just keep looking untill you find a good condition LS tranny.
i know all about the differences in the trannys, but right now im building a car from ground up and buying LS tranny for $50 is just a starter to get it going. I will have a B16 tranny in the future, i promise that but it's hard to turn down a tranny to get it running for $50.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">I would first like to say to shoot for a GSR or type-r tranny if possible. The pin he's referring to is the dowel pin that holds the shift linkage to the shift rod on the transmission. If it's not tapped in flush enough to fit the clip over it, it's not in perfectly. Whoever would install a tranny like that is just lazy. Ask him if it goes into 5th gear...if it does, most likely it will go into reverse.</TD></TR></TABLE>
he says it goes in 5th
i just don't understand... i have a gsr, i have had both the gsr tranny and ls, and i hate that LS piece of crap and when i boost i will definately have my new gsr tranny on there. GSR tranny all the way!!! unless you have 900 wheel horsepower and your going for the world top speed record and need loooooooooooooonnngggggg gears, but i think your like the rest of us and just like going fast on the street/track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyhurtz »</TD></TR><TR><TD CLASS="quote">but for 50 bux, i would buy it too! especially if i need a tranny.</TD></TR></TABLE>
BINGO!!!
now is that the only "pin" that could be wrong with it?
BINGO!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumada9 »</TD></TR><TR><TD CLASS="quote">well if you're running turbo ls tranny will work good with the long gear ratios. but dude, ls cable trannys arent that expensive, just buy one thats in working order.
Care to explain why you think an LS transmission is better for boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neardon »</TD></TR><TR><TD CLASS="quote">
I would just keep looking untill you find a good condition LS tranny.</TD></TR></TABLE>
</TD></TR></TABLE>Care to explain why you think an LS transmission is better for boost?
throughout my experiences with people who've been boosted, they've liked their LS trannys while running boost. I PERSONALLY have never been boosted, so therefore i cannot say which one i like better. such as my friend who had an ef sedan with a b20 motor and b16 tranny, was racing a da w/ b20 and ls tranny, both good drivers. by the time he was shifting to like 5th gear the da was still pulling fourth and pulled on him. so iono. show me a vid of two cars w/ same set up one gsr tranny and one ls that are turboed. prove me wrong
I think you need to read up a little more and stop the bench racing before you get some innocent person killed. Maybe try getting an education, go to school or something. Obviously a tranny with longer gears is going to pull in the top end you act like that is prooving something. I dont need a video I could tell you right now that the gsr tranny will pull untill it tops out then the ls tranny will slowly creep in the end.
If you want to actually learn this stuff, instead of just bench racing to find out what is better here are some links:
http://auto.howstuffworks.com/transmission.htm
http://www.ff-squad.com/tech/temp/Bgears.htm
haha hay neardon and dumada9
are you two like brothers or something?
cuz you talk like you are
neardon you know you could just say the right info and tell dumada that he's wrong but you don't have to insult him
come on guys were all integra owners
so just get along
so just get along
no were not brothers he's just a dick who thinks he knows everything about life. IM giving my personal opinion, people i know who've been turboed, liked the longer gear ratios, so i figure maybe Op will too. If all comes down to what you like, you want short gear ratios, obviously LS isnt the way to go. Gsr tranny is shorter than ls, b16 tranny is shorter than both. Before i get someone killed, OP BE CAREFUL!!! USING AN LS TRANNY ON YOUR TURBOED CAR MIGHT END YOUR LIFE
ha ha, i think that guy was referring to getting someone killed as if someone was gonna race someone else to prove it.
ha but 700hp b18 + LS longgggg gears = 170+ mph top end= DEATH......... to EVO
from my personal experience people i know who've ran turbo, always loved longer gear ratios so i figure Op will too. OH well. Good luck with your set up !! turbo is no joke hahah
if you wanna argue more PM me and stop fuccing up his thread, he knows how each tranny will work now, let him make his choice, PM or stfu
Stop fighting through this guys thread. FUCC if you want to prove your point then PM me and prove it. Stop trying to act like you're better/ smarter than the rest of the world. PM me and save this thread before you fucc it up any further
