Need some input on SuperTech Valves in my Ls/Vtec
Old Nov 5, 2008 | 06:00 PM
Tyconway's Avatar
Default Need some input on SuperTech Valves in my Ls/Vtec
Okay got my Ls/vtec running, 9:1 comp ratio for turbo setup. Gsr head built with supertech valves, dual valve springs and retainers. Had local machine shop do all the work... Heres the question, I had a gsr with hondata s300 with the same skunk 2 intake manifold and injectors that im using on the new ls/vtec. So I figured everything would be fine to just start the engine. when i start the engine it wouldnt idle and i've checked everything twice and check the valve clearances again. it will idle at 1800 but when it falls below that it will make random really loud taps, like the valve springs are popping. but when its idling above 1800 it sounds fine. the tapping sounds happen when it idles down and is about to go dead. But im still curious as to what the sounds are... anyone got any advice? Its not normal honda tickling, the pops are pretty loud.
Stock gsr cams are being used.
Old Nov 5, 2008 | 06:13 PM
LA_HONDAS's Avatar
Default Re: Need some input on SuperTech Valves in my Ls/Vtec (Tyconway)
did you adjust the valve lash that will help alot
Old Nov 5, 2008 | 06:43 PM
Tyconway's Avatar
im gonna double check, go with gsr oem specs or what for Supertech valves and dual springs??
Old Nov 5, 2008 | 06:51 PM
LA_HONDAS's Avatar
Default Re: (Tyconway)
yes gsr
4DR_EK
May 10, 2010 09:43 PM
slowr6
Mar 8, 2007 10:50 PM
D-rush08
Sep 9, 2006 12:07 AM
DC4cedInducted
Dec 13, 2005 03:23 PM
JODYG35950
Jan 29, 2005 05:12 PM
