how to tell from stock ls cams and aftermarket ones
Old Nov 5, 2008 | 05:50 PM
pokmijn's Avatar
Default how to tell from stock ls cams and aftermarket ones
like the question say i want to know cause i got some but dont know what they are.
Old Nov 5, 2008 | 06:11 PM
be8teensee1's Avatar
Default Re: how to tell from stock ls cams and aftermarket ones (pokmijn)
well if they are crowers it will say it in between the lobes( on most )
Old Nov 5, 2008 | 06:12 PM
Default Re: how to tell from stock ls cams and aftermarket ones (be8teensee1)
are they in the car ?
Old Nov 5, 2008 | 06:34 PM
pokmijn's Avatar
no its not in my car the reason i was asking is because i got it from my girlfriend bro and it came out of a built ls head and i just wanted to figure out if it was stock or aftermarket.
The only different i can see is the weight difference.
Old Nov 5, 2008 | 07:26 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default FV-QR
did you ask him what brand they were?
Old Nov 5, 2008 | 07:33 PM
SleepRdc2's Avatar
look at the end of the cam, there might be a stamp. that is where jg puts his.
Old Nov 5, 2008 | 07:45 PM
pokmijn's Avatar
Default Re: (SleepRdc2)
no he doesn't know what it is cause he bought the motor do to lsv so he just didn't need the head and i tried to look for stamps or something cause my crane has number at the end but this one has nothing i would say its stock but its very light compare to the stock cams. does str make cams cause it has str gear on it.
Old Nov 6, 2008 | 07:13 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: (pokmijn)
look and see if there is a part number stamped on either end of the cams.
EDIT: NM, it seems you already looked there.
Old Nov 6, 2008 | 07:27 AM
Default FV-QR
If you wind up taking anything into a machine shop, I would get them measured for the hell of it. I'd say you'd be able to figure out what they are if you posted up the lift, duration, etc.
Old Nov 6, 2008 | 11:50 AM
twentyhurtz's Avatar
Default Re: FV-QR (full Circling)
i'm no expert on cams, but shouldn't you just be able to get a caliper and measure the lobes to the furthest(fattest) point? the factory duration should be published all over honda-tech if searched.
Old Nov 6, 2008 | 02:09 PM
butt_trumpet's Avatar
Default Re: FV-QR (twentyhurtz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyhurtz &raquo;</TD></TR><TR><TD CLASS="quote">i'm no expert on cams, but shouldn't you just be able to get a caliper and measure the lobes to the furthest(fattest) point? the factory duration should be published all over honda-tech if searched.</TD></TR></TABLE>
The lift is the number you're talking about measuring and he'd have to measure the nominal diameter of the cam outside the lift zone and subtract that from the fattest portion of the cam. A ten dollar pair of calipers would do the job.
You can probably get the stock lift numbers from the Crower web site.
Daniel Horvath
Apr 15, 2013 07:14 PM
slowboyy06
Oct 24, 2009 04:41 PM
civic-8442-
Jun 14, 2008 05:31 PM
m3rd3074
Mar 16, 2006 04:02 AM
KingOfQB
Jan 30, 2006 12:58 PM
