Innovate Motorsports | LM-1,LM-2, LC-1, G3 | Guaranteed Lowest Prices Out There!
HT Members,
We are offering at UNBELIEVABLE LOW PRICES Innovate Products. Please PM us for pricing. Guaranteed you will not be disappointed!!! <FONT COLOR="blue"> <FONT SIZE="5"> WE WILL NOT BE UNDERSOLD! </FONT> </FONT>
<FONT COLOR="red"> <FONT SIZE="3"> Classic LM-1 </FONT> </FONT>
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program as seen in the picture above.
The Basic Kit includes: the Meter, a Bosch wide-band oxygen sensor and cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual.
<FONT COLOR="red"> <FONT SIZE="3"> LM-2 </FONT> </FONT>
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
* Patented “Direct Digital” Wideband Technology
* Wideband O2 Compatible with ALL fuel types
* Single or Dual Channel Version Available
* OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
* Log directly to SD card (included)
* Playback log data on screen and/or with powerful LogWorks software (included)
* Large high-contrast graphics LCD
* Built-in RPM converter (direct frequency or with optional inductive clamp)
* 4 fully-differential analog inputs
* 2 configurable linear analog outputs
* Positive lock connectors for all connections
* Innovate MTS serial IN and OUT
* USB connection to your PC
The LM-2 also features two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
The LM-2 Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide. Carrying Case also included!
<FONT COLOR="red"> <FONT SIZE="3"> DB Blue LC-1 </FONT> </FONT>
This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB Blue LED Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
Gauge is 52mm (2 1/16") and features LED display and appears blacked out when powered off.
<FONT COLOR="red"> <FONT SIZE="3"> DB Red LC-1 </FONT></FONT>
This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB Red LED Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
<FONT COLOR="red"> <FONT SIZE="3"> G3 </FONT> </FONT>
This kit comes complete with the patented award-winning LC-1 Wideband Controller, G3 Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
Gauge is 52mm (2 1/16") and features through-dial back lighting, illuminumated pointer, and high-speed stepper motor for immediate response. Also appears blacked out when powered off.
VisualAutoMotoring
Performance
Aug 26, 2010 11:11 PM
VisualAutoMotoring
Nov 27, 2008 11:52 PM
LudeyKrus
Feb 5, 2004 08:38 AM
