TPMS question
Hi,
All I recently upgraded my car (08Civic LX Sedan) on a set of ADR 17" and installed a set of used TPMS sensors which I bought off of ebay. The "TPMS" yellow light is on. The wheels have been mounted and balanced by an expert. I called up the dealer and asked for the part number for the OEM sensors on my car and it is 42753-SNA-A83 and the parts number on the sensor that I bought was 42753-SNA-A810, now my question is, does this matter at all from funcitonality point of view??? on the A810 it says 315mhz and the fcc ID # is GQU-36T not that it matters....
I know the parts numbers are different, but the listing clearly says "06 07 08 Honda Civic Tire Pressure Sensors TPMS OEM"...CIVIC 06-08 (Cpe & Sed, 5 lug), 16x6-1/2, alloy, 7
spoke"
Help me out...as the sensors are alreday mounted I would like to know if this can be fixed by the dealer or my only way out is to unmount the OEM steel wheels(more$$$) and unmount the alloys and swap out the Sensors.........
more $$$$ whould be my last option any ways....
Thankx
JFK
spoke"
Thankx
JFK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stlblues13 »</TD></TR><TR><TD CLASS="quote">I know the dealer has to reset your car to recognize the new sensors. I would start there. </TD></TR></TABLE>
That's what I would do, unless the 'expert' that installed your sensors was a tech from a Honda dealership.
thank you guys...naaa the expert was not the stealer ship....but I will get thereset done firts and see if it picks up the sensor.....thankx for the inputs...
later
later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeusone »</TD></TR><TR><TD CLASS="quote">06 civc doesnt come with tpms.</TD></TR></TABLE>
The part description probably refers to the chassis it fits on, which is the 8th gen from 06-08.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguru »</TD></TR><TR><TD CLASS="quote">so you guys think the when dealer will do the reset the sensors should pick up???
only one way to find out...either call them and ask them of take your car to them. They will most likely charge for resetting the TPMS so the new sensors are communicating with the existing system in the car. And I've read somewhere, its not cheap to get that reset out of warranty and your setup clearly falls out of warranty since neither the sensors nor the wheels are OEM.
</TD></TR></TABLE>only one way to find out...either call them and ask them of take your car to them. They will most likely charge for resetting the TPMS so the new sensors are communicating with the existing system in the car. And I've read somewhere, its not cheap to get that reset out of warranty and your setup clearly falls out of warranty since neither the sensors nor the wheels are OEM.
japspecjohn
Jan 19, 2012 04:34 PM
Marktwo
12
Dec 17, 2003 01:30 PM
ramz7887
Nov 12, 2003 04:15 PM
