How much Hp do the H23 rods hold?
Old Nov 5, 2008 | 08:10 AM
meanshyguy's Avatar
Default How much Hp do the H23 rods hold?
I'm completely rebuilding my motor, I was wondering if I'd be safe using stock H23 connecting rods since compression is at 11:5.1, and I'm gonna use stage 3 crower cams with ported and polished head, will the stock rods be ok?
Old Nov 5, 2008 | 08:25 AM
streetracer6rpt's Avatar
Default Re: How much Hp do the H23 rods hold? (meanshyguy)
i dont see u having a problem with stockers.... if i was u i would go ahead and get some aftermarket rods though, then u know u dont haft to worry about it..
Old Nov 5, 2008 | 08:26 AM
98vtec's Avatar
moderator emeritus
there is no predetermined number.
replace the rod bolts with ARP's and you'll most likely be good to go.
Old Nov 5, 2008 | 08:45 AM
meanshyguy's Avatar
Default Re: How much Hp do the H23 rods hold? (98vtec)
I'll get the arp bolts for them, thanks, crowers are way too expensive.
Modified by meanshyguy at 11:14 AM 11/5/2008
Old Nov 5, 2008 | 08:46 AM
98vtec's Avatar
moderator emeritus
seriously...
http://www.google.com/search?h...=f&oq=
Old Jan 16, 2009 | 12:06 PM
sauceja's Avatar
Just for info. I was quoted 469.00 and about a 5-7 week wait with one person to have h23/f22 rods worked on.
This price included:
shot peened
arp rod bolts
rod bolts installed, caps shaved and honed back to normal size to eliminate the oval shape caused by the new arp rod bolts
LE rebushed to accept a larger 22mm wristpin
For that much money the aftermarket rods that are available or a custom set sounds like an easier and more cost effective way.
Especially considering H23/f22 rods most likely have way over 100,000 miles on them by now.
Old Jan 24, 2009 | 08:30 AM
japscrap's Avatar
Aftermarket F22/H23 rods are like ~$800.
Old Jan 24, 2009 | 11:10 PM
meanshyguy's Avatar
I bought some Probe Industries H23 rods from someone here for around 200 bucks, not a bad deal at all.
Old Jan 26, 2009 | 03:47 PM
japscrap's Avatar
Would H23 cranks and rods be reliable to 7500 RPM with type-s pistons in an H22? Im pretty sure that they would like 98vtec said with some rods bolts.
Old Jan 26, 2009 | 03:51 PM
DLB1994's Avatar
with arp bolts they will be just fine i have made up to 217whp allmotor on them before
Old Jan 26, 2009 | 05:59 PM
japscrap's Avatar
Cool. How far are you reving it?
Old Jan 27, 2009 | 01:01 AM
meanshyguy's Avatar
My bad, I'm using crower stage 2's not stage 3
Old Jan 27, 2009 | 05:11 AM
h23prelude94's Avatar
yes the stock rods should be fine to use i boosted mine with the stock rods at 5psi with stock internals with 70,000 on my motor and it was fine...you will be fine with the stock rods theyr strong enough
Old Jan 27, 2009 | 07:59 AM
dk4ever's Avatar
Not to thread jack, but I've looked on ARP's website and cannot find the part number for the H23 rod bolts that everyone keeps talking about. Another thing, do you torque them to the h22 specs or the h23 specs. I thought h23 specs were too loose compared to the h22 that's why people keep spinning a bearing. If I'm wrong please correct me. I'm just going off speculation myself.
Lude@Heart
Nov 27, 2008 09:26 AM
SP GARAGE
May 25, 2007 07:36 AM
EvR
Jul 30, 2005 11:17 PM
thehatchninja
Apr 30, 2005 04:20 PM
Smurfylude
May 20, 2002 03:15 PM
