Radiator drain plug broke
My drain plug broke on my aftermarket radiator "CSF Radiator No. 2089"
Does anyone know where I can find the specs on the drain plug bolt, or perhaps where I can buy a replacement?
Thanks
Thanks
yeh, just sent them an email. I was hoping to finish up tomorrow, but looks like I might be driving my sister stock integra LS for a few more days...
it is a plastic piece, very UNlike the factory one. I ended up buying a 12mm hex bolt, pitch is 1.25, shortest one I could find was about 1.5 inches long, so I cut it down to 3/8" and then used a dremel to get rid of the threads messed up by the hacksaw. Put some sealant on it and put it in, fit perfectly.
If anyone else has this radiator and need to solve the same problem, it is easy, only costs a couple bucks too.
oh well good luck, and oh here is a tip in case you didn't know this, sometimes when you have to cut a bolt, go ahead and put a nut on it all the way past the portion your gonna cut, then when you cut the bolt, you can unscrew the nut and usually it will clean the threads up when coming off. in your case you probably didn't have enough room anyways because the bolt was so short. that way you won't have to use a dremel
I had just enough room to do that, and I did, but it didn't work. The threads at the end got really f*cked up from the hack saw.
tercelrcr
Jan 8, 2012 02:35 PM
Powered By Garrett
Jul 17, 2008 06:05 PM
